tig ,mig or arc whats best
Old Feb 27, 2006 | 02:50 PM
dazuk's Avatar
Default tig ,mig or arc whats best
i need to know whats best for making a custom turbo manifold (log manifold)
tig mig or arc and whats the second best just incase i have trouble finding some one to do one of them
thanks in advance
Old Feb 27, 2006 | 03:20 PM
FastCougar's Avatar
Default Re: tig ,mig or arc whats best (dazuk)
The order in which you have the methods is the best. First TIG, then MIG, then Arc (would never recommend Arc/stick because it's very hard to do on thin metal).
Old Feb 27, 2006 | 03:30 PM
KevinACrider's Avatar
Default Re: tig ,mig or arc whats best (FastCougar)
When doing thick metal, is ARC alot easier? Say for a cage or something?
Old Feb 27, 2006 | 03:41 PM
dazuk's Avatar
Default Re: tig ,mig or arc whats best (KevinACrider)
i know some one who can do mig and arc
also i was told about arc being hard to do thin metal by my dad but he also mention how my grandfather used to be able to weld car body panels with arc
Old Feb 27, 2006 | 03:42 PM
dazuk's Avatar
it will be schedule 40 is that mig or arc thickness
Old Feb 27, 2006 | 03:47 PM
stinker504's Avatar
Manifolds are best done with a tig. I only arc weld when I need to weld something greater than .25".
Old Feb 27, 2006 | 05:27 PM
weiRtech's Avatar
OG Fabricator
get a tig. you can also arc weld with most tig machines.
Old Feb 27, 2006 | 05:46 PM
ManBearPig4silly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevinACrider &raquo;</TD></TR><TR><TD CLASS="quote">When doing thick metal, is ARC alot easier? Say for a cage or something?</TD></TR></TABLE>
No it wouldnt be easier to build a cage with a stick welder and please dont try it.
Old Feb 27, 2006 | 05:49 PM
self_made's Avatar
tried all three processes(mig's arc'd and tig'd turbo manifolds), and tig's the best way to go
Old Feb 27, 2006 | 10:23 PM
dazuk's Avatar
so mig is best bet if i cant find some one to tig
i am quite confident i can build it my self but have never welded in my life
but i do have access to a mig could i build it and spot weld it together and take it to some one to weld it properly or would the spot welds cause problems for the welder
Old Feb 28, 2006 | 09:36 AM
k24em2's Avatar
None of those is better than the other. They are designed for different things and all work well when used as intended. For automotive applications GTAW or GMAW is preferred over SMAW. If you have never welded before a GMAW power supply would be recommended.
Old Feb 28, 2006 | 10:15 AM
supercreed2002's Avatar
Default Re: tig ,mig or arc whats best (k24em2)
I wish I had money for a nice tig, but mig might be easiest for a non-experience welder...maybe.....
Old Feb 28, 2006 | 10:28 AM
dazuk's Avatar
i understand they have different uses but i have said what the intended use is(turbo manifold)
also i have no idea what GMAW,GTAW,SMAW MEANS
thanks for advice guys
Old Feb 28, 2006 | 02:15 PM
k24em2's Avatar
Default Re: (dazuk)
GTAW=Gas Tungsten Arc Welding (TIG)
GMAW=Gas Metal Arc Welding (MIG)
FCAW=Flux Cored Arc Welding (Flux core)
SMAW=Sheilded Metal Arc Welding (Stick)
There are a few others that aren't really applicable to the automotive industry.
I would recommend a MIG.
Tegiwa Imports
Welding / Fabrication
Dec 5, 2010 10:32 PM
Mixmasta
Oct 18, 2007 05:07 AM
Matt_Sturbo
Mar 26, 2007 10:10 AM
renegadez7o7
Dec 14, 2005 04:08 PM
chinoty
Jul 16, 2005 10:34 AM
