cracked rear crossmember
Old Feb 27, 2006 | 02:50 PM
Slink2000's Avatar
Default cracked rear crossmember
I have a 91 si hb with the a b16a. I changed my oil and put in new axles, and while I was under my car I noticed that the rear crossmember was cracked. My ? is would this cause my car to pull to the right hard and make the passenger tire to look pushed back towards the door? Also if you stand in front of the car the driver side wheel is straight and the passenger side wheel is pointing out a little (as if you where turning right.)
Any input would be great.
Old Feb 27, 2006 | 02:52 PM
Tyson's Avatar
Default Re: cracked rear crossmember (Slink2000)
um, yeah. sounds like youve had some major damage in the past. id consider all your suspension parts suspect. measure and compare each part to see if its not just the crossmember that needs replacement.
Old Feb 27, 2006 | 02:59 PM
rsca_crx's Avatar
do you mean rear x-member like at the rear wheels, or are you talking about the rearward front x-member where the steering rack is?
Old Feb 27, 2006 | 03:01 PM
Slink2000's Avatar
Default Re: cracked rear crossmember (rsca_crx)
Where the steering rack is.
Old Feb 27, 2006 | 03:02 PM
crxnj's Avatar
Default Re: cracked rear crossmember (Tyson)
My car was previously in an accident..And It needed a radius rod..Replaced it found out the lca was bent,,replaced that found out the upper control arm was bent,replaced that and went to the alignment shop and found out my crossmember was bent..I had the same problem as you though..My passenger wheel was pointed to the right and pushed so far back it was almost in the door..Just hope you dont have as big a problem as me
Old Feb 27, 2006 | 03:09 PM
Slink2000's Avatar
Default Re: cracked rear crossmember (Mr.speaker)
Thanks for the info, hopefully I don't have that big of a problem.
Old Feb 27, 2006 | 03:14 PM
rsca_crx's Avatar
grab a junkyard x-member from a straight car and get it on there. replace components that don't bolt up, and then see if you can align everything to spec.
be careful with the bolts that hold the xmember on since getting everything to line up can be a pain if the car or the new xmember are tweaked and you don't want to cross thread anything.
Old Feb 27, 2006 | 03:21 PM
mintef's Avatar
when installing the crossmember be sure to use pry board/screwdriver align the crossmember. there are holes in the crossmember that match up with holes in the frame and then tighten the bolts
Old Feb 27, 2006 | 07:29 PM
Slink2000's Avatar
Default Re: (mintef)
alright thanks, looks like my next project for the weekend.
Old Mar 27, 2006 | 10:02 AM
Slink2000's Avatar
Default Re: (Slink2000)
I am doing this 2morrow. Is there any bushings you would recomened to replace?
jonyi27
Jun 20, 2014 11:35 AM
static-x
Suspension & Brakes
Jan 7, 2010 02:31 PM
govtec
Mar 7, 2005 06:48 AM
TheBestCRX
Oct 24, 2003 09:36 AM
rice_classic
Feb 8, 2002 09:13 PM
