OT: what size air compressor is enough?
Old Mar 29, 2002 | 10:05 AM
non-VTEC's Avatar
Default OT: what size air compressor is enough?
if you wanted to run a 1/2" impact gun.
something that can keep up with the air supply demads the gun needs.
currently i'm looking at 2. one is a CH 3HP belt drive pump with 16 gallon tank. and the other is also a CH 5HP belt drive pump with 22 gallon tank. and there's about a 140 dollar diffrence between the two.
i'm kinda leaning toward the 3HP one for the price but some might say the 5HP is better.............
any suggestions?
Old Mar 29, 2002 | 10:32 AM
flex97itr's Avatar
Default Re: OT: what size air compressor is enough? (non-VTEC)
if i was you i would get a stronger one, trust me in the long run you'll be saved from mad headaches
Old Mar 29, 2002 | 05:38 PM
D.Lansing's Avatar
Default Re: OT: what size air compressor is enough? (flex97itr)
SCFM is more important when looking for a compressor than hp. Get the one that is higher
Old Mar 29, 2002 | 07:16 PM
EG8R's Avatar
Default Re: OT: what size air compressor is enough? (D.Lansing)
Go with the bigger one. You'll kick yourself if you don't
Old Mar 29, 2002 | 07:34 PM
Eric R's Avatar
Default Re: OT: what size air compressor is enough? (mr. skelly)
A 1/2" impact gun will empty that 16 gallon tank in a heart beat. The air compressor will kick in every few minutes. You're better off with the 22 gallon one or bigger if you can afford it.
Old Mar 29, 2002 | 07:44 PM
travis's Avatar
Default Re: OT: what size air compressor is enough? ('01ITR#950)
Spend the money on a larger tank. The size of the compressor isn't as important, except for the fact that a larger compressor should last longer because it's working below it's max to keep the tank full. In the long run, $1-200 isn't that big for a tool that you will have for a long time.
Old Mar 29, 2002 | 10:07 PM
brinks's Avatar
I have a 5hp crafstsman with a 20 or 25 gal tank- i forget which. Good compressor for my 1/2 inch gun. Good warranty too, you can just take it back to sears, tey that with a CH. Something to consider is that if you go larger than 20 or 25 gal. you might not be able to tramsport it in the car if need be.
Old Mar 30, 2002 | 03:17 AM
non-VTEC's Avatar
there both rated at 125psi. i'm sure the regulator can be changed to get 130-140psi out of it.
i think i'll go for the 5hp/22gallon one........thanks......
blaze.1
Paint and Body
Feb 26, 2009 07:16 PM
girliehonda
Aug 24, 2007 07:55 PM
Vanilla Sky
Welding / Fabrication
Jan 18, 2005 06:16 PM
