Replacing rear trailing arm bushings
Old Feb 27, 2006 | 11:30 AM
Reelizmpro's Avatar
Default Replacing rear trailing arm bushings
I think the bushing where the arm meets the body might be shot and the cause of my knocking sound when turning left (perhaps right rear bushing). When I look up the arm in the parts catalog it doesn't list a separate part number for the bushing just the entire arm. Please tell me I don't have to order the entire arm. If so, perhaps time for rear disc swap. Thanks.
Old Feb 27, 2006 | 11:32 AM
CRX Toad's Avatar
Default Re: Replacing rear trailing arm bushings (Reelizmpro)
Do you still have the stock trailing arms? If you do you can get the bushing at Honda. They can order just the bushing for you.
Old Feb 27, 2006 | 11:56 AM
Tyson's Avatar
hey barry. hope your front end is still riding well.
heres a ton of info on rta bushings. popular topic in the rr/ax forum.
https://honda-tech.com/zerothread?id=1511567
Old Feb 27, 2006 | 11:59 AM
Targa250R's Avatar
be professional
http://www.performanceforum.co....html
Old Feb 27, 2006 | 12:00 PM
Tyson's Avatar
Default Re: Replacing rear trailing arm bushings (Targa250R)
theres a lot more info we discuss in the thread, including wes' link above.
Old Feb 27, 2006 | 12:30 PM
Reelizmpro's Avatar
Thanks guys, that's just what I was looking/hoping for. Tyson, the front end is much better than before although still has some shimmy under breaking. I still have those old cross drilled rotors on there so I'm going to wait until I change those out before I start messing with the suspension again. I need to do that other front lower ball joint soon though. I'll give ya a ring one of these weekends. Been busy with school. Thanks bro.
Old Feb 27, 2006 | 01:31 PM
Sequoyah's Avatar
I'm pretty sure everything was covered above (didn't read through it) but I just ordered two new rear trailing arm bushings from Majestic Honda and these are the part/product numbers:
Part# 52385-SR3-000
Product# 375227
They are $39.23 each and came to $83.41+shipping. You use the same part# for the L & the R sides
blaak-crx
Suspension & Brakes
10
Jun 2, 2008 05:14 PM
deviant1
40
Feb 22, 2005 08:35 AM
Wes d
Jan 2, 2002 11:11 AM
