which way are the wheel bearings pressed in?
Old Feb 27, 2006 | 10:55 AM
immalooser's Avatar
Default which way are the wheel bearings pressed in?
well i got my new bearings in a cl hubs. and i'm wondering which way the bearings are supposed to be pressed in?
Old Feb 27, 2006 | 05:54 PM
snyderman5's Avatar
Default Re: which way are the wheel bearings pressed in? (immalooser)
whatever side has the rubber is the side that gets pressed to the hub
Old Feb 27, 2006 | 09:27 PM
Dmc1's Avatar
A cool science class experiment like way to press the bearing in is you Take the bearing put it in the freezer for an hour and take the hub and put it in your oven for a few minutes preheated to 200. Quickly take the cold bearing out of the freezer and drop it in the hub.
Ive done that to change bearings in my dirt bike a few times it's easy.Just remember to use an oven mitt.And make sure the lady of the house isn't home to B*&^%
Old Feb 27, 2006 | 10:59 PM
Honda_Accord's Avatar
Default Re: which way are the wheel bearings pressed in? (Dmc1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">
amen
Old Feb 28, 2006 | 12:43 AM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">A cool science class experiment like way to press the bearing in is you Take the bearing put it in the freezer for an hour and take the hub and put it in your oven for a few minutes preheated to 200. Quickly take the cold bearing out of the freezer and drop it in the hub.
wouldnt u expand the hub and shrink the bearing, making it even harder to put on?
usually when i want to slide someone over something else, i heat the outer ring, and cool the inner ring. like if i wanted to put a bearing race into the tranny case, i heat the case and cool the bearing race. heat expands the case, and cold shrinks the race
Old Feb 28, 2006 | 12:44 AM
Eddiebx's Avatar
oh for the original questionthe way you had it in the first picture is correct
76 camaro car
Jan 19, 2015 09:28 AM
Nhilcrest
Apr 10, 2011 12:23 PM
huge230
Apr 1, 2008 05:38 PM
ViZ
Feb 11, 2005 07:52 PM
monsterb18b
Sep 22, 2004 05:45 PM
