GSR radiator in a EF w/ swap. Will it fit?
Old Feb 27, 2006 | 10:41 AM
red_EF9Si's Avatar
Default GSR radiator in a EF w/ swap. Will it fit?
I need to replace my radiator badly so I found a GSR one locally but I'm unsure if there is enough clearance for it. I tried searching but that yielded more questions than answeres. This is for my 90 hatch with B16 swap. Anyone have this radiator or know for a fact it will fit? Any input is appreciated, thanks in advance.
Old Feb 27, 2006 | 02:36 PM
red_EF9Si's Avatar
anyone?
Old Feb 27, 2006 | 03:05 PM
HT Chaplain's Avatar
Loved
Default Re: (red_EF9Si)
i would use the original one for a 90 civic
Old Feb 27, 2006 | 09:26 PM
red_EF9Si's Avatar
up.
Old Feb 27, 2006 | 11:46 PM
Mach69's Avatar
Your failure to mention what year integra has us bringing no answers to you.
The DA radiators will fit and will be a VERY tight squeeze.
Never tried a DC radiator, but I believe it won't fit.
Old Feb 28, 2006 | 01:56 AM
FOMULA91's Avatar
Default Re: (Mach69)
Me and my friend tried it, but it was way to big.
Old Feb 28, 2006 | 08:52 AM
beyondspexj's Avatar
yes it will fit. its gunna sit close and use a slim fan. there was a write up about it on sho but i read that like 3 years ago when i first got my crx.
Old Feb 28, 2006 | 09:17 AM
HandCommand's Avatar
Default Re: GSR radiator in a EF w/ swap. Will it fit? (red_EF9Si)
For all of my customers that get a B-series swap into their EF CRX's and Hatches, I use a 90-93 Integra DUAL CORE radiator.
It bolts right into the stock location and uses the same mounts. Whats even nice is that it has B-series size radiator hose INLETS and OUTLETS to match the B-series motor that is being swapped in.
You could just buy another stock radiator, but you will have to squeeze down the B-series hoses to fit the smaller D-series radiator INLETS and OUTLETS.
Old Feb 28, 2006 | 09:21 AM
red_EF9Si's Avatar
Default Re: GSR radiator in a EF w/ swap. Will it fit? (HandCommand)
Thanks for the info that might be my best bet. Is there a difference in size between the OEM DA LS/GS and GSR radiators??
90cb4door
Jun 22, 2010 06:36 PM
EF9_RIDER37
Apr 3, 2010 08:57 PM
95_red_dc
Feb 6, 2009 10:31 AM
ep4life
Mar 19, 2008 10:14 PM
d16vtecx
Jan 7, 2006 09:22 PM
