manifold help
I've searched the forums but couldnt find an answer to the following:
As part of my build I was thinking of getting an AEM V2 induction and VENOM inlet manifold, but I have been advised that this is a bad idea as the two dont go well together.
Hence.. I have been told that:
The venom inlet manifold will make most power between 6000-8000 rpm
The v2 will make most power between 3000-4000 rpm
Is this true?
I have also been advised that for top end power you would be looking at :
a 4 to 1 exhaust manfold
cold air intake
inlet manifold with short fatter runners (skunk2 ect)
for midrange power you would be looking at :
a 4-2- 1 exhaust manfold
short ram intake
inlet manifold with longer runners (ported stock manifold)
If this is true which would be more suited to VTEC?
Many thanks.
Is this true?
cold air intake
short ram intake
Many thanks.
