4th Gen Door air vents(searched already)
Old Feb 27, 2006 | 10:00 AM
CliffBurton's Avatar
Default 4th Gen Door air vents(searched already)
I was wondering if anyone knew if the air vents that are on the doors of the 4th gen prelude are removable or not. Mine are pretty dusty and I wanted to take them out and clean them out thoroughly.
Thanks in advance
Old Feb 27, 2006 | 10:23 AM
mgags7's Avatar
im sure you can get them out, either way you could take the door panel off and get a good angle to clean them
Old Feb 27, 2006 | 10:24 AM
Default Re: (mgags7)
I'm going to give it a try. Thanks for the help
ps. I'll update later if you can or cannot simply remove the vents
Old Feb 27, 2006 | 10:33 AM
kulrevon's Avatar
Default Re: (CliffBurton)
Do you mean the airvents that point the window or the person.
I have removed the ones that point at the person just don't loose the little things that go on the swivel points. You will see them when you pull the vent out.
Old Feb 27, 2006 | 10:42 AM
Default Re: (kulrevon)
The ones that point at the person. Do they just pull out, or do you have to take off the panel to get to them properly?
Old Feb 27, 2006 | 11:05 AM
eluder33's Avatar
they pull out by uncliping the clips at 3 and 9 o'clock on the vent. I stuck a thin blade screwdriver in there to get mine out and pushed from the backside, that'll only work if you have small arms
Old Feb 27, 2006 | 11:43 AM
Slatelude's Avatar
Default Re: (mattman33)
open the door which allows acces to the backside of those vents and they can be easily pushed out as the unit.
K
Old Feb 27, 2006 | 11:59 AM
Default Re: (Slatelude)
Thanks guys. I used the screwdriver method, and they came out pretty easily. They were very, very dusty. Some water and a lot of q-tips solved that problem
Old Feb 27, 2006 | 12:17 PM
97Preludeguy's Avatar
Air compressors get the job done as well
ekhatchey
Jan 29, 2011 06:38 PM
raylude
Paint and Body
Apr 18, 2010 03:08 PM
ludedude00
May 5, 2005 06:09 AM
LordVtec
Feb 12, 2003 05:56 PM
wizurd
Feb 27, 2002 11:22 AM
