question with 96 type r suspension (brake rotors)
Old Feb 27, 2006 | 07:12 AM
TEAM562racing's Avatar
Default question with 96 type r suspension (brake rotors)
I have an ek and just put on the 4x114
96 type r suspension.
the brake rotors are pretty old and need to be replaced. besides ordering aftermarket jdm brand rotors from japan can i just get brembo or powerslot or any easy to get crossdrilled rotors here in the u.s.?
if so what car do buy them for since the 96 type r was never available in the states?
i'm pretty sure i just need to buy regular integra brake pads but if anyone can confirm that as well i would appreciate it.
thanks.
Old Feb 27, 2006 | 07:21 AM
Circuit Star-29's Avatar
Default Re: question with 96 type r suspension (TEAM562racing)
check into other models w/ that same lug pattern. Take your rotor into your local parts store and compare them if they have something.
I think some Accords, Preludes and Legends have that lug pattern. Check into that.
Old Feb 27, 2006 | 10:18 AM
YumVTEC's Avatar
96-97 JDM ITR brakes use the same diameter rotors as GS-R (but different lug pattern) 10.6", and the same calipers and pads also as a GS-R. You can get 92-96 prelude VTEC rotors (4x114.3) but they are bigger and I don't believe they will work with the stock calipers and pads, you would have to get prelude VTEC or USDM ITR (or JDM 98+ ITR) calipers and pads. your best bet is to get a set of 4x100 rotors and have them re-drilled to 4x114.3.
this has been discussed a gazillion times.
Old Feb 27, 2006 | 11:26 AM
thanks for the info guys
Old Feb 27, 2006 | 06:30 PM
808dc2's Avatar
If you want to upgrade, I've got a brand new pair of brembo 11.2' Prelude VTEC front rotors(4x114.3) and 98+ ITR front calipers.
Old Feb 28, 2006 | 08:12 AM
KOALA YUMMIES's Avatar
No one did this but all your info was right up at the top of this forum, or just a click away:
Brakes - 96Spec ITR
https://honda-tech.com/zerothread?id=753762
https://honda-tech.com/zerothread?id=696362
https://honda-tech.com/zerothread?id=514109
https://honda-tech.com/zerothread?id=507924
DC2R82
Mar 27, 2012 12:08 PM
TWEKCOUPE
Sep 17, 2007 12:37 PM
4F_ Mugen CoL
25
Sep 6, 2007 03:37 AM
botlebruiser
10
Oct 31, 2006 02:12 PM
zRd#1
Mar 27, 2004 08:24 PM
