D15Z1 in an 88 Std, O2 sensor
Old Feb 27, 2006 | 02:04 AM
VegasEFHB's Avatar
Default D15Z1 in an 88 Std, O2 sensor
I have a D15Z1 (93 VX) going into my baby, and the only parts I have yet to acquire are the little crap. The only BIG deal is the O2 sensor. I know the OEM 93 VX had a 5wire O2, and I am duplicating the OBD1 setup on my 88 Hatch (full OBD1/Vtec conversion and using the OEM 93 VX ECU). My question is this, though, can I use a 4 wire and get away with it or do I NEED the 5 wire to make it function properly?
Old Feb 27, 2006 | 04:42 AM
davens's Avatar
I don't know for sure, but I'm assuming its intentionally a five wire for a reason.
I was extremely pissed when I found my other car needed this same type of o2 sensor. It was $390 something from the dealer and the direct fit from Autozone was $270ish and they didn't carry a universal version. Ridiculous!
Luckily I found a universal five wire on Ebay for about $60.
Old Feb 27, 2006 | 02:17 PM
VegasEFHB's Avatar
Default Re: (davens)
yeah, I don't want to pay more for a simple O2 sensor than the harness conversion kit. I am hoping I can get it to work with a 4 wire, if not I might be down a little bit longer til I can get one at a reasonable price
Old Feb 28, 2006 | 04:42 AM
StorminMatt's Avatar
Default Re: D15Z1 in an 88 Std, O2 sensor (VegasEFHB)
I think the CA model Civic VX uses a four wire sensor. You could always get a CA ECU and just wire up a four wire sensor. The sensor itself is MUCH cheaper.
Old Feb 28, 2006 | 10:48 AM
VegasEFHB's Avatar
Default Re: D15Z1 in an 88 Std, O2 sensor (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">I think the CA model Civic VX uses a four wire sensor. You could always get a CA ECU and just wire up a four wire sensor. The sensor itself is MUCH cheaper. </TD></TR></TABLE>
I am fairly certain that the motor I have is a Cali motor anyways, that woud work quite well.
I also found this : http://cgi.ebay.com/ebaymotors...%3AIT
I think if I had to do a 5 wire, it would work quite well.
halfkoreanboy
23
Feb 4, 2011 06:03 PM
hunterhound
Jul 24, 2008 05:13 PM
vxtirent08
Apr 15, 2008 10:15 AM
1.8
Mar 29, 2006 10:30 PM
boredracer408
Dec 3, 2005 03:06 AM
