Torque Specs on ITR Motor
Old Feb 26, 2006 | 11:59 PM
USDM EG's Avatar
Default Torque Specs on ITR Motor
Whats up H-T,
I took my cams out to redo some things i didnt like..
Well i dont have the torque specs for the caps, cam gear bolt, and tension bolt along with crank.
Does anyone have a book and could they take a pic?
I orderd a book and its on hella back order.
Help me out! Im dying to hear VTEC again!
Old Feb 27, 2006 | 11:18 AM
ITRnorway's Avatar
Default Re: Torque Specs on ITR Motor (USDM EG)
well my Haynes book tells me:
cam caps: 6mm bolts - 86INCH-lbs! 8mm bolts - 20ft-lbs
camshaft sprocket: 41 ft-lbs
tensioner for timing belt: 40 ft-leb
cankshaft pully bolt: 130 ft-lbs
i dont have any pictures of the tightening sequence on the cam caps on this computer, but im sure some other guys can help you
i cant find anyting about the cam caps should be torqued in steps, or just finger tight all the bolts first.
this is for b18c1/5 engines
Old Feb 27, 2006 | 11:58 AM
totsie7944's Avatar
Default Re: Torque Specs on ITR Motor (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Time to purchase a haynes manual. Which one did you order?
You know, I can manipulate your bold statement in your sig with an ITR engine, and a civic.</TD></TR></TABLE>
Play nice haha
Old Feb 27, 2006 | 12:22 PM
USDM EG's Avatar
Default Re: Torque Specs on ITR Motor (totsie7944)
i ordered a helms, and yeah, they told me its on back order
Old Feb 28, 2006 | 12:20 PM
USDM EG's Avatar
sweet thanks
dome
Nov 4, 2006 02:14 PM
USDM EG
Feb 28, 2006 12:19 PM
Tim2179
Aug 28, 2005 06:02 PM
EK FLY
Jun 5, 2005 08:04 PM
dabomb
Oct 5, 2003 07:05 PM
