6 speed transmission for ITR?
Old Feb 26, 2006 | 07:36 PM
powersteer's Avatar
Default Any 6 speeder for ITR?
sorry for the noob Qn,
Have u guys came acrosse any aftermkt kits to convert the stk g/b into a 6 speeder? or have u guys seen anyone makes 6 speed g/b for DC2R?
Old Feb 26, 2006 | 08:11 PM
Chris F's Avatar
Default Re: Any 6 speeder for ITR? (powersteer)
Cheapest way would be to swap in a K-series from an RSX/TSX, engine and tranny.
Old Feb 26, 2006 | 09:21 PM
ITR 692's Avatar
but...WHY?
Old Feb 26, 2006 | 09:38 PM
itr1244's Avatar
Default Re: Any 6 speeder for ITR? (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Cheapest way would be to swap in a K-series from an RSX/TSX, engine and tranny.</TD></TR></TABLE>
Old Feb 26, 2006 | 10:06 PM
ekim952522000's Avatar
Default Re: Any 6 speeder for ITR? (itr1244)
Old Feb 26, 2006 | 10:59 PM
norice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRaceRx1 &raquo;</TD></TR><TR><TD CLASS="quote">but... WHY?</TD></TR></TABLE>
Because is 6 is more than 5 so it must be better .
Old Feb 26, 2006 | 11:15 PM
Rednas's Avatar
Default Re: Any 6 speeder for ITR? (norice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norice &raquo;</TD></TR><TR><TD CLASS="quote">Because is 6 is more than 5 so it must be better .</TD></TR></TABLE>
Old Feb 27, 2006 | 01:34 AM
powersteer's Avatar
basically, my stock ratios isnt well optimised for the circuit that i'm running on. I figured that a 6 speeder will help me to close up the gap between 3,4,5.
I can choose to change my ratios to suit, but I thought ... If I were to open up my g/b, and if a 6 speeder is available, i might as well go for that.
oh, and a K series wudnt be considered as I love my B series very very much :D
Old Feb 27, 2006 | 03:11 AM
Bradstard's Avatar
Just get yourself one of these...
http://www.quaifeamerica.com/t...g.htm
Old Feb 27, 2006 | 03:51 AM
jond's Avatar
Theres no reason for a 6 speed IMO.
The gear ratio in the ITR is PERFECT. And it gets 30mpg. Unless you're shooting for 35mpg highway, I dont see the purpose...
Old Feb 27, 2006 | 04:05 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: (powersteer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powersteer &raquo;</TD></TR><TR><TD CLASS="quote">basically, my stock ratios isnt well optimised for the circuit that i'm running on. I figured that a 6 speeder will help me to close up the gap between 3,4,5.</TD></TR></TABLE>
If you're shifting at redline, then your next gear will be in the max torque range. It should be OK.
If you are having to shift in the middle of a corner then in most cases you could carry the next gear up. In most cases you'll appear to be slower at first (even though you might not actually be slower), but you will gain speed as you get used to being one gear up.
Something else you might want to think about is moving from the USDM 4.40 final driver to JDM 4.78 or one of the aftermarket ratios.
There is no cheap way to put a 6 speed transmission into a DC2 ITR w/a B motor.
Old Feb 27, 2006 | 04:43 AM
Back in Black's Avatar
Rather OG
which isn't cheap.
I'm with George. I'd think about investing in another FD, or perhaps a gear set. The only reason I went with a K is so I could be competitive in my class with a stock drivetrain.
Good luck
Old Feb 27, 2006 | 05:19 AM
jond's Avatar
Default Re: (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">If you are having to shift in the middle of a corner then in most cases you could carry the next gear up. In most cases you'll appear to be slower at first (even though you might not actually be slower), but you will gain speed as you get used to being one gear up.</TD></TR></TABLE>
Good point, I was thinking about just street driving. One problem I notice on the track is sometimes I'm leaving a corner around 4,000rpm and I have to wait for 6,000 before the fun kicks back in...
Dont know if thats what the original poster was talking about?
Old Feb 27, 2006 | 06:32 AM
Opie's Avatar
Default Re: Any 6 speeder for ITR? (Rednas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rednas &raquo;</TD></TR><TR><TD CLASS="quote">
Way to pick up on the sarcasm, douche.
I would try to ugrade your FD as others have said. If you don't think it has filled the void then you can explore more (expensive) options.
Old Feb 27, 2006 | 06:48 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Any 6 speeder for ITR? (Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">Just get yourself one of these...
$19000! Plus it isn't easily compatible with a Honda. Morbid curiousity made me click.
Old Feb 27, 2006 | 06:51 AM
chad's Avatar
Moderator
Default Re: Any 6 speeder for ITR? (jond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">Theres no reason for a 6 speed IMO.
then you don't understand about a 6speed tranny!!
Old Feb 27, 2006 | 07:07 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powersteer &raquo;</TD></TR><TR><TD CLASS="quote">Have u guys came acrosse any aftermkt kits to convert the stk g/b into a 6 speeder? or have u guys seen anyone makes 6 speed g/b for DC2R?</TD></TR></TABLE>
Technically you already have 6 speeds. Though, only 5 of them go in the forward direction.
Old Feb 27, 2006 | 07:10 AM
Dave_B's Avatar
Technically you already have 6 speeds. Though, only 5 of them go in the forward direction.</TD></TR></TABLE>
No sir, you have 3, that are split
Old Feb 27, 2006 | 07:24 AM
Circuit Star-29's Avatar
Default Re: Any 6 speeder for ITR? (Dave_B)
Check out a cross gear set. Thats my next buy.
Old Feb 27, 2006 | 08:13 AM
Arsenal's Avatar
The gear ratio in the ITR is PERFECT. And it gets 30mpg. Unless you're shooting for 35mpg highway, I dont see the purpose...</TD></TR></TABLE>
There is no such Utopia.
As the origional post states that he needs it for a specific track formation, as such he needs closer gear ratios.
To say that the gear ratios are perfect may be true for yourself, but the other 10K ITR owners may differ, thats why he is asking.
I am pretty sure that MPG is the least of his worries considering he is worried about exit speeds.
Old Feb 27, 2006 | 04:13 PM
Hybrid ctr's Avatar
Default Re: Any 6 speeder for ITR? (Arsenal)
ATS FD or 3-4-5 close gear set - probably your best options
Old Feb 27, 2006 | 06:40 PM
#1151's Avatar
uhhmm honda makes one for the K20 ..swap a k20z, and BAM 6 speed.
Old Feb 27, 2006 | 07:10 PM
JjuuN R's Avatar
i'd love to have one of these
Old Mar 1, 2006 | 06:34 AM
powersteer's Avatar
hmm .. guess i will have to make do with the current ratios and MOD the driver instead
btw, mine is already running 4.785 as its a JDM '98 ITR
Old Mar 1, 2006 | 07:05 AM
RagingAngel's Avatar
swap out the 4th and 5th gears for 96spec 4th and 5th and that'll shorten things up noticeably.
I've had the 98spec transmission setup before as well and felt it didn't suit the ITR's inherent urgent nature.
NVH (noise vibration harshness) be damned....
