WTF IS WRONG
Old Feb 26, 2006 | 07:10 PM
HONDA_CIVIC_HATCH_Boy's Avatar
Default WTF IS WRONG
ok im driving around town and all of a sudden my car dies. i tried starting it but it would start. i let it sit for 5 mins or so and it started right up. i start to pull out of a parking lot about a block later and it dies again. let it sit for 5 mins again and it starts. why is my car doing this. it cranks over but it wont start. if i let is sit awhile it starts right up. i just hope it not my fuel pump .
please help me out here.
Old Feb 26, 2006 | 07:14 PM
Runnerdown's Avatar
Default Re: WTF IS WRONG (HONDA_CIVIC_HATCH_Boy)
internet diagnosis is not that easy
but anyways, based off what you said my first guess would be distributor/ignition problems.
Old Feb 26, 2006 | 08:15 PM
ef2_civic's Avatar
Default Re: WTF IS WRONG (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote"> my first guess would be distributor/ignition problems. </TD></TR></TABLE>
feel the same
Old Feb 26, 2006 | 08:19 PM
CRXCRAZYD16Y8's Avatar
i would check the main relay. it sounds like the problem. listen for 3 click from under the dash.
1st click is when u turn the igntion on
2nd click is after the cel turn off
3rd is when u try to start it ( may be hard to hear)
mostly just try to listen for your fuel pump turn on for about 2 seconds before u crank the starter. main relays can go bad, and there can be cracks inside it to where it does this when it gets hot.
basicly just listen for the fuel pump and and or clicks.
fyi: main relay is about $60 - 70 at autozone, i had to replace mine because of this.
good luck
Old Feb 26, 2006 | 08:21 PM
i could be ignition problems too, like they said.
u just gotta start with the simple things, but i had this prob before, mine was the main relay but u could have something diff, let me know what happens
Old Feb 26, 2006 | 08:24 PM
SiR Inspired ED7's Avatar
Main Relay?
Old Feb 27, 2006 | 06:17 PM
ya, the efi main relay, up under the dash by ur left foot
albert7
29
Feb 7, 2017 03:12 PM
sle.simon
Sep 7, 2006 01:28 AM
mingbling96
Jun 1, 2006 06:51 PM
TheOne
Apr 9, 2003 06:15 AM
PurduePete
Feb 17, 2003 04:22 AM
