Rear Capliper Slid Pin.
Well Make a long story short I was doing some rear brake work over the weekend. The drivers side had a stuck slide pin. I mean real stuck. A two pound hammer and about 50,000 whacks then ****** came out.
My question is that I looked online and I get two different part numbers.
Pin A or Pin B
Do you guys know which one I need?
Thanks
-Dan
Pin A or Pin B
Thanks
-Dan
well it was probably stuck from rust, not being greased up properly oyu should replace the mounting bracket that the pin goes it in may casue problems later on if u dont
TouringAccord
Nov 17, 2014 11:27 AM
NACvicSi
Sep 5, 2009 12:15 PM
