lightened flywheel
would it benefit me greatly to get a lightend flywheel? i have a b16a1 in my 89 hatch. i have the y1 tranny with the real short gears. i dont want to spend the money on it if im not going to benifit from it a lot. ill spend the money somewhere esle. thanks
I have b16 in my 88 rex si both a flywheel and clutch and I noticed a big difference in throttle response and I would suggest you go ahead and spend the money on a set.I use clutchmasters and I will only use them from now on,Im very pleased at their product,as a matter of fact I can get you a deal on it if you want.
hey, my 91si rex finally needs a new clutch, and i was wondering if a clutch masters clutch is good? ... also is it harder to press the pedal down?
my friend was saying that "high-performance" clutches don't last as long, ....is this true? ...(if so, then i would rather get a normal one), if you could give an opinion, that would be cool, tahnks
SLATER97EX
Nov 17, 2004 02:16 PM
Naturally Aspirated
21
Aug 10, 2004 06:51 PM
StolenTeg
Aug 3, 2004 10:33 PM
