Can you change pistons with crank in block?
Old Mar 29, 2002 | 05:32 AM
Westrock2000's Avatar
Default Can you change pistons with crank in block?
Can I change the rods or pistons by just cranking the crank till its all the way down on the selected piston and just unblot the rod and pull the piston out? From the bottom...or push out the top too I guess.
Old Mar 29, 2002 | 06:09 AM
canuck-mx6's Avatar
Default Re: Can you change pistons with crank in block? (Westrock2000)
You can unbolt the rods from the crank and push the pistons out the top. You have to remove the head first though
samagon's Avatar
Default Re: Can you change pistons with crank in block? (canuck-mx6)
and the oil pan
Old Mar 29, 2002 | 06:23 AM
BSQ's Avatar
BSQ
You will also need to hone the cylinder walls so the piston rings will seat properly.
Old Mar 29, 2002 | 06:30 AM
non-VTEC's Avatar
can be done.........head has to come off.........
Old Mar 29, 2002 | 06:52 AM
Evil DOHC's Avatar
Default Re: Can you change pistons with crank in block? (non-VTEC)
Easy to do. Lift the head, take off oil pan, oil pickup and gurdle. Then just unscrew the rods/caps and pop the piston up. When you do hone the head, make sure you do it right, or you will cause yourself more headache than its worth.
EVIL
Old Mar 29, 2002 | 07:05 AM
brinks's Avatar
Default Re: Can you change pistons with crank in block? (Evil GS-R)
EVIL
hone the head??
maybe too much for you eh?
Old Mar 30, 2002 | 03:58 PM
Default Re: Can you change pistons with crank in block? (brinks)
Does a shop have to hone it....Honeing (sp?) is just a real lite abrading right...boring is the more elaboratoe one where they take of the 0.25 or whatever? Honeing just makes the surface nice and smooth again right...so can the engine stay in for this to get done is what I'm wondering?
Old Mar 30, 2002 | 04:18 PM
non-VTEC's Avatar
technically you can hone the cylinder walls yourself while the engine is still inside the car. all your doing is removing the "shine" on the cylinder walls to help the new piston rings seat.
you will need a cylinder hone or glaze breaker. it's not the best was or doind it but it can be done and it works ok.
Old Mar 30, 2002 | 04:28 PM
Malice's Avatar
New User
is it absoleutely necessary to hone the block when getting new pistons? or is it just recommended? thanks
Old Mar 30, 2002 | 04:31 PM
non-VTEC's Avatar
Default Re: Can you change pistons with crank in block? (MaliceGSR)
it's deffinatly recommended especially if you have alot of miles on the engine.
if you dont it will take twice as long for the piston rings to properly seat. and even then they might not seat properly and you will have oil consumption.
if you do it yourself with the engine in the car it should take about an hour to complete one all the pistons are out. just make sure you clean the cylinder walls throughly before installing the new pistons and rings.
all-mtr-teg
26
Jun 13, 2008 11:14 PM
d1nki
Jun 16, 2007 10:19 AM
001020
Mar 20, 2005 06:51 PM
001020
Mar 19, 2005 11:14 AM
EKB18BPR3
Jun 2, 2004 11:34 PM
