91 manual windows...
Old Feb 26, 2006 | 12:11 PM
KillerElfboy's Avatar
Default 91 manual windows...
91 DX sedan, the windows are being real hard to roll down and dont go down all the way,
is there a way to fix this back to normal?
Old Feb 26, 2006 | 09:36 PM
Trumpster's Avatar
Default Re: 91 manual windows... (KillerElfboy)
Pop the door panel and check to see if the window is off the track, that's been known to make windows not roll all the way down. You may need to re-grease the tracks to make it roll down easier. If you need to know how to pop the door panel, you can get a Haynes repair manual at your local auto parts store for about $15. You will need to pull the window crank (handle) off, pop the little screw guards off the doors (one is on the lower left [if you're doing the drivers side door] of the door panel, and the other is in the handle itself. There is also a screw in the handle that actually opens the door, in order to get the door panel off you will need to unscrew that screw and then remove that actual handle assembly. Good luck!
Old Feb 26, 2006 | 09:42 PM
Default Re: 91 manual windows... (Trumpster)
awesome, thanks man, do i need any special tools or greaser for it?
Old Feb 26, 2006 | 10:15 PM
Trumpster's Avatar
As long as you have the basic tools, phillips and flat head screw drivers, you'll be fine. As far as the grease goes, I would probably recommend bearing grease for the tracks. It lasts for a long time and you should be able to pick up a little tub of it from your local auto parts store for cheap.
Old Feb 26, 2006 | 10:36 PM
YeuEmMaiMai's Avatar
it would also be a good idea to lune your window guides and any other parts that come in contact with each other during the window operation while you got that door panel off
jalexcar
Jul 12, 2008 09:21 AM
vlc92189
Oct 8, 2006 10:17 AM
C2daIzZle
Sep 8, 2005 10:01 AM
Thrillhouse
Apr 14, 2002 11:30 AM
davidbui
12
Jan 8, 2002 07:32 AM
