lighting problem on ep3
Ok this is now at the point where I just might start the car on fire! This is what happen. Ok the other day get out to get gas, turn off the lights and go to turn them back on and WAM no low beams. I have high beams no low. So I figure ahh no biggy either a fuse or the bulb went. Well after replacing the bulb bulb and EVERY FUSE in the car nothing. So next was the relay. try to replace those and nothing. Still no low beam. So I got out the old trust-e mulit meter and started testing away. I have high beams. So it's just low beams. For so reson no power is going to them. Has anyone had this problem or something like this. Oh yeah I can also hear and feal the relays working. See under the hood you have the 2 relays (left and right) as well as the 2 fuses. They are all fine. SO it has to be something else. I am at the going mad part...lol Any help would be great.
I had problem before, but it was only the driver side. I had those PIAA Extreme Whites in my EP3 and just replaced them both with SilverStars and they worked again for me. But that's all I can give you.
check at the bulb plug with your test light see if its giving power to the low beams there it ALSO can be your combination switch on the dash, might be faulty
