Full-Race B Series ProStreet Stage 3GT 88-91 civic/crx turbo kit
4000$
Stage 3GT Turbo Kit is designed for the true street/strip racer looking for instant spool and huge top end. This kit is intended for fully built engines, and will make more power sooner than ANY large sized turbo kit on the market today. No other kit can come close. Power is up to 650whp, while still retaining exceptional spool characteristics!
For those who can afford it, this turbo kit makes the best powerband of any turbo kit on the market presently. Instant spool and huge power are why this kit has been hailed the ultimate kit by a number of the US's top tuners. This kit does retain PS but is not AC compatible.
It is brand new! never been used just took everything out of box to inspect when i got it!
Kit includes:
Full-Race T3 ProStreet Manifold
# Thick wall stainless steel construction
# Bottom mount design
# Precision robotic TIG welding
# Made in the USA
Full-Race 3" 4-bolt Downpipe
# Stainless steel construction
# Precision hand TIG welding
# Smooth transition for maximum performance
Full-Race Intercooler
# All aluminum Air-to-Air Intercoolers are oven braze, 100% TIG welded and have 15 fins per inch.
# Measures 20"x8"x3"
# Extruded tube and fin design for minimal pressure drop
# Innovative backdoor design
Full-Race GT35R Ball Bearing Turbo
# Different trims and ARs available to support your power goals.
Tial 44mm Wastegate
# Multiple spring rates available
Tial 50mm Blow Off Valve
# Non recirculating valve, billet aluminum, extremely high quality
Full-Race Intercooler Piping
# 2.5 in. mandrel bent aluminum
Full-Race Oil Line Kit
# Feed and return from block to oil pan and everything in between.
Full-Race Vacuum Line Kit
# All lines and fitting required to plumb the turbo system and related accesories.
Full-Race Hardware Kit
# Includes all hardware required to bolt on the kit.
Full-Race Gasket Kit
# Includes all necessary gaskets.
Full-Race Silicon Coupler Kit
# 2.5" silicon couplers with Full Race logo. Couplers are constructed from 2 ply fiberglass reinforced silicone with a 110 wall thickness.
Full-Race Hose Clamp Kit
# T-bolt clamps included for every coupler.
There are intercooler pipes to that i dont have pictures its a complete turbo kit from full-race.
Kit includes:
# Made in the USA
Tial 44mm Wastegate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caspers_sfwd »</TD></TR><TR><TD CLASS="quote">d-series?</TD></TR></TABLE>
It's designed for a B series in an ED chassis.
