what kind of rod bearing can i use with aftermarket rods on ls block?
Old Mar 29, 2002 | 01:54 AM
civicguy's Avatar
Default what kind of rod bearing can i use with aftermarket rods on ls block?
do i need honda bearings?or does the rods manufacturer tells you what color you need if you use oem bearings?or i will have to plstigage to know the color ?
thanks
Old Mar 29, 2002 | 03:48 AM
BROOD's Avatar
Default Re: what kind of rod bearing can i use with aftermarket rods on ls block? (civicguy)
Use Honda bearings only (goes for rods and mains)
The rod manufacturer should be able to tell you what # size their rods are compared to oem Honda rods. (example: Eagle rods for a B18/B20 are equal to Honda #3 rods, Eagle rods for a B16/H22 are equal to Honda #2 rods)
Match that number up with the letters on the crankshaft and look up the color bearings you will need in a service manual.
[Modified by SLPR, 4:50 AM 3/29/2002]
Old Mar 29, 2002 | 04:56 AM
Evil DOHC's Avatar
Default Re: what kind of rod bearing can i use with aftermarket rods on ls block? (SLPR)
Most likely it will be green color code for the rod bearings. I would call crower, etc. and ask them how they machined the rods. If worst comes to worst, when the machine shop balances the buttom end for you, they can check the clearances and tell you what size/color bearings to order.
EVIL
jlfrnce
Nov 30, 2009 05:17 PM
douglas_be
Feb 23, 2004 09:17 AM
nicklk
Feb 9, 2004 06:41 PM
slooowDX
Aug 5, 2002 07:33 PM
