Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
what camber do you run?
Old Feb 25, 2006 | 10:06 PM
Leb_CRX's Avatar
Default what camber do you run?
just wonder, I know it's personal preference, just wondering so I have an idea of what to start off with and work from
Old Feb 25, 2006 | 10:09 PM
chad's Avatar
Moderator
Default Re: what camber do you run? (Leb_CRX)
2.7 front 1.7 rear
Old Feb 25, 2006 | 10:15 PM
: alexander :'s Avatar
Default Re: what camber do you run? (chad)
somewhere between 1 f/r I'm not to keen on maximum cornering setups because being able to use it is a rarity unlike straightline traction which my car sometimes lacks as is.
Old Feb 26, 2006 | 12:14 AM
Johnny Mac's Avatar
Default Re: what camber do you run? (suavacito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suavacito &raquo;</TD></TR><TR><TD CLASS="quote">somewhere between 1 f/r I'm not to keen on maximum cornering setups because being able to use it is a rarity unlike straightline traction which my car sometimes lacks as is.</TD></TR></TABLE>
I heard a dude named Stormy uses mad camber in the front and even madder in the rear.
Old Feb 26, 2006 | 04:45 AM
George Knighton's Avatar
H-T Order of Merit
2.5 Front / 1.5 Rear, on an HPDE DC2.
But I'm old and slow.
Old Feb 26, 2006 | 05:12 AM
Track rat's Avatar
Default Re: what camber do you run? (George Knighton)
3.0 - 3.5 front, 2.5 rear... on a DC2 used for track only.
Old Feb 26, 2006 | 06:34 AM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
90 crx -2.75 in front and -1.5 rear. currently wasting away waiting for swap. used mainly as HPDE car
Old Feb 26, 2006 | 07:57 AM
Nishant's Avatar
Default Re: what camber do you run? (o-man)
-1.8 in the front
-2.8 to -3.0 in the rear
S2000
Old Feb 26, 2006 | 09:23 AM
BrianZ's Avatar
-4 front -3.5 rear and as much caster as I can get out of the car (usually around +3)
DC race car
Old Feb 26, 2006 | 09:42 AM
mikeski38's Avatar
-5 front, -4.5 rear. DA race car
Old Feb 26, 2006 | 10:08 AM
FlyZlow's Avatar
Default Re: (mikeski38)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeski38 &raquo;</TD></TR><TR><TD CLASS="quote">-5 front, -4.5 rear. DA race car</TD></TR></TABLE>
Wow Mike .. that's a lot of camber. Do your temps come out looking pretty even that way? I'm think I'm going to do some testing at Cal Speedway in a couple weeks to get mine where it should be for the roval tracks. I've never even measured it on the new car.
- Scott
Old Feb 26, 2006 | 10:19 AM
cursED's Avatar
Default Re: Camber
- 2.2 front, - 1.2 rear camber for HPDE/auto-X/daily driver '90 Civic hatch with B-16 swap.
Old Feb 26, 2006 | 03:13 PM
eficker's Avatar
Default Re: Camber (cursED)
-2.7 front, -1.7 rear, dd DA.
Old Feb 26, 2006 | 06:15 PM
White98LS's Avatar
Default Re: Camber (eficker)
2.0 F, 1.4 R, daily driver/auto-x.
Old Feb 27, 2006 | 06:02 AM
mikeski38's Avatar
Default Re: (FlyZlow)
If I could run more I would. The car just gets faster the camber I put in. My tires are about 15-35 degrees hotter in the inside. And I like that slammed look!
Old Feb 27, 2006 | 08:06 AM
1gCRX90's Avatar
I like negative camber, but that's just because I'm a hater.
What kind of car (i'm presuming a CRX by your name, but what year?), what kind of activity? Street? Auto-X? Road Race? What kind of tires and wheels? I imagine that depending on what you're doing alignment settings will vary widely.
That being said, typically as much negative camber as possible with the understanding that excessive negative camber may affect your straight line braking performance. Or so I've heard.
Old Feb 27, 2006 | 08:31 AM
Leb_CRX's Avatar
Default Re: what camber do you run? (1gCRX90)
ya my nickname's misleading (and old...heh), I've had a 97 ek for about 3 years now
it is a daily driver but for activies, pretty much some road course but mostly auto-x , regarding tires to be honest I am not sure what I will be running next year, i am hoping for some azenis if I can find another set of rims to use, and I haven't fully made up my mind yet
I was just looking to see what kind of #'s most people ran, and set it up with something close and play around with it, and go from there...from the looks of it I am going to start with -2.5f and -1.5r and go from there
Old Feb 27, 2006 | 11:57 AM
solo-x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeski38 &raquo;</TD></TR><TR><TD CLASS="quote">If I could run more I would. The car just gets faster the camber I put in. My tires are about 15-35 degrees hotter in the inside. And I like that slammed look! </TD></TR></TABLE>
not that surprising, considering your choice of suspension. 15-35 degrees hotter on the inside edge sounds about right, assuming you aren't locking the brakes or generating a lot of wheelspin. if you have a bit of both, i'd still think you're running too little static. -6* static has got to do some damage to brake/accel performance though, so i'd be hesitant to recommend more static camber. perhaps some stiffer linear springs and some low speed shock force? did you guys splurge on data aq with your DMS stuff, or still flying SOP style?
on my ST car i'm running nearly 3 degrees negative up front, less then 1 degree negative on the rear. these ball park numbers don't mean squat without knowing what spring and bar rates you're running or what tires. my setup is fairly stiff but with the street tires i run on i could still stand another half degree or so of camber. another ST car i've been helping develop is running very high spring rates and had good success with over -4.5*'s of camber. again more likely due to the type of tire then anything else.
nate
ForceFed Motorsports
Suspension & Brakes
Feb 5, 2006 11:00 AM
hughesl
12
Oct 4, 2005 11:31 PM
mugenintegra16
Sep 20, 2005 07:46 AM
B HATCH
132
Jul 23, 2005 03:16 PM
luckypon7
Dec 28, 2004 07:19 PM
