90 civic swap gone bad .....bad rings??? #'s inside
The engine is a B18a1 obd1 i recently had the valves reground and replaced the head gasket. I was never able to get the engine to run after the machine work
the bottom end has 144000 miles on it
leakdown / comp.test (no 30wtoil) / comp.test(with oil)
#1 20% / 90 psi / 280 psi
#2 25% / 95 psi / 240 psi
#3 20% / 90 psi / 190 psi
#4 20% / 90 psi / 180 psi
Im about to pull this thing out and rebuild it.
i would def say bad rings that is a huge difference in compression numbers! wow! 240--->180 holy begees
rebuild
rebuild
looks like rings to me that is a big differnce 100psi damn 240 seems really high for an ls dont it though
either way its time for some rings and p30 pisons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dat_dude_Ken »</TD></TR><TR><TD CLASS="quote">im going to do another leak down test tonight , but it doesn't look to good
no it dosent, 240, are you sure your guage works rite?
</TD></TR></TABLE>no it dosent, 240, are you sure your guage works rite?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91whiteZCrex »</TD></TR><TR><TD CLASS="quote">
no it dosent, 240, are you sure your guage works rite?</TD></TR></TABLE> hmmm.....not sure, but i do have 2 different gages ill try it with both gauges again. you can never be too sure.
owneyboy
Apr 7, 2011 08:19 PM
