Toda B's and Smog, how u do it?
Old Mar 28, 2002 | 10:30 PM
comptechgsr's Avatar
Default Toda B's and Smog, how u do it?
how u do it?
hahahah, seriously i got tagged by the cops...
what's the procedure
Old Mar 28, 2002 | 11:40 PM
Art Vandeleigh's Avatar
Default Re: Toda B's and Smog, how u do it? (comptechgsr)
i have asked this numerous times but no one ever says anything and i know some people have toda b in their rides....do you all just pay people off??
Old Mar 28, 2002 | 11:50 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Toda B's and Smog, how u do it? (cali-r)
Um.
Ok, I'm going to guess that you want to know how to pass emissions testing with Spec B's. It's very simple - zero out your cam gears and lean the **** out of your fuel correction.
Old Mar 28, 2002 | 11:57 PM
Default Re: Toda B's and Smog, how u do it? (itr009)
my friend has toda b on his gsr, he left the cam gears at +3in 0ex and he leaned it out big time and he still did notpass smog. he just decided to sell the cams. i dont hink he set the gears back to 00, but he did lean it out and he still did not passs the sniff test.
[Modified by cali-r, 8:58 AM 3/29/2002]
Old Mar 29, 2002 | 12:01 AM
Splat's Avatar
ZERO ZERO on the cam gears. Less overlap. Less dumped fuel. Bet you a he failed hydrocarbons.
Old Mar 29, 2002 | 12:09 AM
i just didnt want to crack open his vc to set the gears to 00 i didnt think it would have made that much of a difference cos the speed shop said it wouldnt pass either....might be wrong lets go get that
Old Mar 29, 2002 | 04:21 AM
Back in Black's Avatar
Rather OG
Pat's correct...
0,0/lean = passed emissions
Old Mar 29, 2002 | 05:27 AM
non-VTEC's Avatar
try -2 intake +2 exhaust and lean out the fuel a little.
also retard the ignition timing to the minium factory spec or even a little less.
Old Mar 29, 2002 | 05:47 AM
H-PIMP's Avatar
Default Re: Toda B's and Smog, how u do it? (non-VTEC)
You don't.
Old Mar 29, 2002 | 06:12 AM
dplatt's Avatar
Default Re: Toda B's and Smog, how u do it? (H-PIMP)
Well, yes you do. I have Toda Bs on my custom B18C5 setup and I passed the strict Oregon rolling (dyno type) emissions test. This is what I ran first (swapped out the test pipe for custom Catco cat with 2.5" flange and fuel curve flat across the V-AFC.
http://www.imagestation.com/picture/...d.jpg.orig.jpg
I ran it again and this time reduced the fuel curve -2 all the way across the board on the V-AFC and I passed with flying colors. THC dropped to 0.87, Nox stayed near 0.39, and CO dropped to 5.3. It is possible to pass with Toda Spec Bs. I made a couple of runs before this with the cam gears not set at zero, zero, just to see and I failed miserably. Cam gears MUST be at 0,0 to have a prayer of passing.
Old Mar 29, 2002 | 08:40 AM
bhcvc's Avatar
Default Re: Toda B's and Smog, how u do it? (dplatt)
Do you guys have higher compression also? I asked the question about 11.5CR and mild cams (ITR/Spoon/Skunk2-1) in a GSR and no one could tell me if it'd pass or fail. Some ppl have told me that higher CR will make me fail. Also, if I increase bore size significantly, it would fail. Thanks.
Old Mar 29, 2002 | 09:48 AM
Splat's Avatar
You don't.
My car passed.
(Stock compression, bhcvcc.)
Old Mar 29, 2002 | 10:01 AM
dplatt's Avatar
Here's my setup. I just put in the cat, made the changes above, and passed.
Balanced B18C1 Block w/ JDM P73 Internals (11:1CR)
USDM ITR Top End (Head, Intake Manifold, TB)
Portflow Headwork w/ Bronze Valve Guides
Toda Dual Valve Springs
Crower Titanium Retainers
Toda Spec B Cams
Toda Gen 2 Cam Gears (+2, -0)
RC 270cc Injectors
BBK 255lph Fuel Pump
STR Competition Fuel Rail
B&M CommandFlo Fuel Pressure Modifier (45psi)
Toda Program OBD-1 P22 ECU
Apexi V-AFC (VTEC x-over @ 6200rpm)
MSD SCI-L Ignition (Rev Limit @ 9400rpm)
MSD High Vibration Coil
MSD Pro Distributor Cap
GSR YS1 Cable Transmission
13lb. Lightened & Balanced Stock Flywheel
Akimoto Funnel Ram II Intake
Custom Cold Air Extension
JUN 4-2-1 SS Header
OBX-R Resonated Test Pipe w/ 2.5” flange
Greddy Sport Cat Back Exhaust
Old Mar 29, 2002 | 12:53 PM
norice's Avatar
Has anybody legitimately passed emissions with Toda Bs in California - as far as I can tell, all the responses have been from other states. Requirements differ from state to state (and, as far as I know, 2000+ ITRs in California have to meet stricter emissions that pre-2000 cars).
Old Mar 29, 2002 | 01:10 PM
Austin's Avatar
Default Re: Toda B's and Smog, how u do it? (norice)
Dino...sounds like you've been hit with the dreaded CARB sticker...you're going to have to put the car back to almost stock...just use pieces that have CARB #'s for your car, then you're going to have to take it into the CARB referee...ask Lawrence or RBoosted717 on what they had to do in order to get Mike's car to pass.
Austin
Old Mar 29, 2002 | 02:14 PM
STOLEN - ITR 98-0652's Avatar
Find a crooked shop. They're a dime a dozen...
Play dumb... break out your wallet... pass CA smog.
Old Apr 3, 2002 | 02:13 PM
Default Re: Toda B's and Smog, how u do it? (Buzz8400)
bump bump, anyone do it or what?
geometro
Oct 6, 2006 12:05 PM
jeffk182
28
Mar 9, 2005 12:19 AM
B18CXr
Jul 24, 2002 08:29 PM
comptechgsr
May 14, 2002 10:26 AM
powerfulperformance
Aug 12, 2001 06:32 AM
