98 Honda Accord Code P1382
Old Feb 25, 2006 | 12:51 PM
zzzhondazzz's Avatar
Default 98 Honda Accord Code P1382
My check engine light is on and hooked up a scanner and it reads P1382 no signel and in the book it says replace the distributor and i did. The code keeps comming back wtf Help, Z
Old Feb 25, 2006 | 04:03 PM
hondadude's Avatar
Default Re: 98 Honda Accord Code P1382 (zzzhondazzz)
I'd think the book you have is trash if it says to diagnose by replacing parts.
Get some better info and an ohm meter; there are continuity test you can do to find the problem in the wiring or ECU.
Old Feb 25, 2006 | 04:07 PM
BuCxLuXoRX2o0o's Avatar
P1382 Cylinder Position(CYP) Senor No Signal
Old Feb 25, 2006 | 08:03 PM
So what should i do??
Old Feb 25, 2006 | 09:23 PM
mmorgan94
Mar 4, 2021 02:09 PM
98honda51
Dec 31, 2016 05:31 PM
ssiruuk60
Jun 15, 2007 04:57 PM
Rob!
Apr 9, 2004 04:40 PM
