defected axle causes vibration?
Old Feb 25, 2006 | 11:22 AM
DC2SIR-G's Avatar
* B A N N E D *
Default defected axle causes vibration?
my left side axle is defected.. im wondering if this can be the reaason why its vibrating at acceleration?
Old Feb 25, 2006 | 11:38 AM
PLAGUED_DB7's Avatar
Default Re: defected axle causes vibration? (DC2SIR-G)
yup. If its defective why are you still using it?
you could do some major damage....
Old Feb 25, 2006 | 04:06 PM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: defected axle causes vibration? (PLAGUED_DB7)
my right side inner cv joint is defected.. is it gonna cause that bad of damages?
Old Feb 25, 2006 | 05:50 PM
jomama's Avatar
there have been quite a few threads regarding shakings lately... they're all regarding either axles, bushings, etc...
Old Feb 25, 2006 | 05:51 PM
jomama's Avatar
oh, and another thing... a lot of people experience shaking during braking and going over bumps. is this you? you mentioned during accelerating
Old Feb 25, 2006 | 06:18 PM
Tornadom's Avatar
My left side axle blew the boot off of the CV joint, and spewed grease all over the underside of the car. Prior to it doing this, it would have a strong vibration under acceleration, especially while under a load. Cruising on the freeway was the worst. I installed a new axle, and the problem was gone.
Old Feb 25, 2006 | 08:36 PM
92DAIntegraXSI's Avatar
Default Re: defected axle causes vibration? (Tornadom)
im on my third set of <U>new</U> axels and my car still vibrates im just guna live with it untill i finish my lsvtec build and when i pull the motor we'll see wat happens i think it might be my intermdeiate shaft who knows im so fed up with it i just ignore it
Old Feb 26, 2006 | 01:58 AM
DC2SIR-G's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom &raquo;</TD></TR><TR><TD CLASS="quote">My left side axle blew the boot off of the CV joint, and spewed grease all over the underside of the car. Prior to it doing this, it would have a strong vibration under acceleration, especially while under a load. Cruising on the freeway was the worst. I installed a new axle, and the problem was gone.</TD></TR></TABLE>
praying to be in same situation like u
Old Feb 26, 2006 | 07:48 AM
Tornadom's Avatar
New axles fixed it for me. Good luck.
Old Feb 26, 2006 | 08:02 AM
Sam92Teg's Avatar
New axles didn't fix it for me, until I fixed the broken rear mount that was allowing the inner joints on the new axles to wear and cause vibration during acceleration.
Old Feb 26, 2006 | 12:55 PM
Default Re: defected axle causes vibration? (Sam92Teg)
hmm i wonder if my ES insert maybe is falling out maybe causing my vibration too?
Old Feb 26, 2006 | 01:01 PM
CivicSiDriver02's Avatar
Default Re: defected axle causes vibration? (92DAIntegraXSI)
The bearing in your intermediate shaft could have gone bad also. Grab a hold of your inner cv joint and move it up down to check it. If you notice any play, replace the bearing/intermediate shaft assembly.
Old Feb 26, 2006 | 01:33 PM
DC2SIR-G's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">New axles didn't fix it for me, until I fixed the broken rear mount that was allowing the inner joints on the new axles to wear and cause vibration during acceleration. </TD></TR></TABLE>
can it be fixed by ES inserts?
Old Feb 26, 2006 | 06:13 PM
Default Re: defected axle causes vibration? (CivicSiDriver02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiDriver02 &raquo;</TD></TR><TR><TD CLASS="quote">The bearing in your intermediate shaft could have gone bad also. Grab a hold of your inner cv joint and move it up down to check it. If you notice any play, replace the bearing/intermediate shaft assembly.</TD></TR></TABLE>
well as far as the shaft having any play it is going to have a very small amount
hcaulfield57
11
Feb 5, 2017 09:19 PM
Pwnmeister
Jun 25, 2013 07:55 AM
taimysho0
Jul 8, 2009 01:29 PM
wu tang
14
Dec 17, 2007 09:23 AM
sinfulDB1
Dec 2, 2003 10:53 AM
