Clutch pedal drops to floor
Unlike the Civic, The Accord uses a Hydralically controlled clutch release mechanism. Here is a parts lay-out drawing of the system.
http://www.hondaautomotivepart...INDER
The Clutch master Cylinder (as mentioned by 93cb7sedan) is number #7 in the illustration.
You should take the time to inspect the entire system b4 you replace anything b'cuz 1 out of 10 failures are of the Slave Cylinder (#10).
A leaking Slave will be very apparent (since it's out in the open). The Master Cylinder leaks (however) inside the compartment; directly in front of the clutch pedal.
P
P
Try looking in your Clutch MC if you have any more fluid left. If not you have a leak somewhere. First place to check would be behind the clutch pedal and see if its wet. Second place would be your Slave cylinder as mentioned.
I had that EXACT same problem. They had to replace this hydrolic piece that enguages the clutch. From the dealer it was around 400$. That should fix the problem. dont worry
This is a pretty common problem. For a quick fix, check your brake fluid level, and top it off it it is low. Then give the clutch a few pumps.
Chances are though you will have to replace either the master or the slave cylinder (as stated earlier).
I had that issue in my 1990 Accord but it happened slowly. My slave cylinder was spewing fluid like you wouldn't believe and my master cylinder was starting to leak a little too. Check the slave cylinder first.
Good luck.
Good luck.
i used to have the same problem, and i couldnt shift into gear, i just kept on stepping on it til it retract bak up, and everafter i never had the problem again
Master Cylinder has been replaced.
Everything held for about 300 miles, then this morning clutch pedal on the floor and no fluid in the reservoir.
So, slave cylinder is next. Right? Or could it be that the system needs to be bleed better?
Could a bad clutch also have these symptoms?
BTW 256k miles original clutch.
Thanks,
Scott
Thanks,
Scott
I assume a 'new' Master Cylinder, right?
Recheck everything, the system doesn't have enough volume to suck the fluid reservoir dry from just air.
I'd give a close eyeball at the slave cylinder next
P
Unless the Clutch Pressure Plate had a catastrophic spring or release lever failure, the pedal wouldn't go to the floor for that.
P
cleansi
Aug 13, 2012 05:21 PM
s1ngle
13
Sep 21, 2005 12:01 PM
FLCivic
Jun 30, 2004 03:48 PM
