Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Will he make it to Fontana in 2 weeks?
Old Feb 25, 2006 | 07:11 AM
thawley's Avatar
Default Will he make it to Fontana in 2 weeks?
Photos taken on Feb 24. California Speedway season opener is on March 11/12.
Old Feb 25, 2006 | 07:14 AM
tnord's Avatar
Default Re: Will he make it to Fontana in 2 weeks? (thawley)
question.....does he have a normal day job he has to attend, or is this his job?
Old Feb 25, 2006 | 07:15 AM
thawley's Avatar
Default Re: Will he make it to Fontana in 2 weeks? (tnord)
Can you define NORMAL?
Old Feb 25, 2006 | 07:16 AM
EdoMoto's Avatar
I votes sure. You better be there John.
Edo
Old Feb 25, 2006 | 07:53 AM
tnord's Avatar
your time is occupied from 8-5 m-f such that you cannot work on the car.
Old Feb 25, 2006 | 08:24 AM
smokin rubber's Avatar
are you working on it right now?
Old Feb 25, 2006 | 08:30 AM
: alexander :'s Avatar
Default Re: (smokin rubber)
define "make it"
one could assume by this you mean tow
Old Feb 25, 2006 | 08:43 AM
prkiller's Avatar
Default Re: (suavacito)
Wow John, and I thought I have some stuff to do! Yikes...
Were you seam welding the car?
Old Feb 25, 2006 | 09:27 AM
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord &raquo;</TD></TR><TR><TD CLASS="quote">your time is occupied from 8-5 m-f such that you cannot work on the car.</TD></TR></TABLE>
Not that normal, no.
Old Feb 25, 2006 | 09:50 AM
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokin rubber &raquo;</TD></TR><TR><TD CLASS="quote">are you working on it right now?</TD></TR></TABLE>
In a few minutes... Had to take my daughter to basketball this morning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suavacito &raquo;</TD></TR><TR><TD CLASS="quote">define "make it" </TD></TR></TABLE>
Pass tech and race with the Honda Challenge group.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prkiller &raquo;</TD></TR><TR><TD CLASS="quote">Were you seam welding the car?</TD></TR></TABLE>
Yeah, maybe just a bit. And welding up some needless holes in the firewall, rebuilding the wiring harness (to move the main fuse box into the passenger compartment), paint and generally make the engine bay easier spend time with.
Also adding a few Autometer gauges, a new Hondata S300, some race compound bushings for the HASport engine mounts, an ACT flywheel, a new DC 4-2-1 header, AEM cam gears, fuel rail & fuel pressure regulator, a weld-in oil pan baffle kit from Heeltoe, a relocated NRG-CELL battery also from Heeltoe, some 310 injectors and a Walbro 255 pump from TunerToys and a couple tricks I'm gonna keep to myself at the moment.
Oh, and a stock (for now) B20.
Got to go now. Bye.
Old Feb 25, 2006 | 11:06 AM
jeffhaut's Avatar
keep us posted, looks like goos times.
ps i voted youd make it.
Old Feb 25, 2006 | 12:08 PM
prkiller's Avatar
Default Re: (thawley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley &raquo;</TD></TR><TR><TD CLASS="quote">
Got to go now. Bye.</TD></TR></TABLE>
Wow, with all that, do you think I'm still gonna pass you John!
Gonna have a fight for Ryan now?
Sounds like you have a load of work ahead of you. I don't envy that! Good luck with it Hope to see you at cali speedway!
Old Feb 25, 2006 | 12:34 PM
johng's Avatar
I'll say it right now.. no way.
If I'm wrong, I owe you a six-pack. Wanna take that bet?
Old Feb 25, 2006 | 01:42 PM
tnord's Avatar
Default Re: Will he make it to Fontana in 2 weeks? (johng)
i'm gonna go with no on this one.
Old Feb 25, 2006 | 05:01 PM
civicrr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johng &raquo;</TD></TR><TR><TD CLASS="quote">I'll say it right now.. no way.
I'm with him - unless you have it @ a professional shop & they devote all their time to it.
Old Feb 25, 2006 | 05:15 PM
mtm68's Avatar
you can do it.
Old Feb 25, 2006 | 06:25 PM
thawley's Avatar
Progess...
Photo by Kurt. Welder by Lincoln Electric
Old Feb 25, 2006 | 08:54 PM
Realek4's Avatar
Pizza was good!
Old Feb 25, 2006 | 09:12 PM
BrianZ's Avatar
can we say some assembly required..
Old Feb 25, 2006 | 10:07 PM
chad's Avatar
Moderator
this could be the reason i don't have an s300 yet?? hahaha....jk....good luck....i have to put a cage in my car in next 3 weeks!
Old Feb 25, 2006 | 10:21 PM
prkiller's Avatar
Default Re: Will he make it to Fontana in 2 weeks? (chad)
I think you can do it John!
Gonna take some hard long hours though!
You better be at cali!
Old Feb 25, 2006 | 11:20 PM
thawley's Avatar
Default Re: Will he make it to Fontana in 2 weeks? (prkiller)
Good day in the garage, today. It's still a shell, but its a better shell. Engine and wiring harness are closer to being useful. Front end and steering are rebuilt. Rear fenders rolled (with a BFH) for 225s. Fuel tank leak fixed, didn't have to empty a single fire extinguisher. Accidentally welded firewall hole for the speedo cable. Guess I won't be running the stock IP after all.
Weld, grind and paint engine bay tomorrow...
Thanks to:
• Aaron Bonk: engine stuff
• Sador Bota: rear fenders, rear susp., engine mounts
• Brandon: block off plate fab, Bota help, showing up to help a guy he's never met
• Rich Hayes: Steering rack, lower ball joints, fuel tank advise
• Doug Macmillan: wiring/ECU, OBD-this, OBD-that
• Kurt Niebuhr: Grinding, metal fab, killer photos
• My wife: putting up with me and all this race car stuff
Old Feb 25, 2006 | 11:29 PM
prkiller's Avatar
Keep it up John!
Old Feb 25, 2006 | 11:43 PM
Ekasey's Avatar
Should have let me know John i would have thrown in a hand or two, if there's more work to be done you have the number
Old Feb 26, 2006 | 05:51 AM
thawley's Avatar
Default Re: Will he make it to Fontana in 2 weeks? (Ekasey)
Thanks. I'm sure I'll taske you up on that.
