B16 overheating when car is not moving.
Old Feb 24, 2006 | 10:25 PM
Chief Wenceslaw's Avatar
Default B16 overheating when car is not moving.
Everytime I'm at a stop light, I just sit and watch the heat gauge go up. After about 2 minutes, it's pinned at the top. As soon as I start going though, it goes down in about 4-6 seconds. I just don't get it. My radiator fan is working, and although I had a radiator leak earlier, I patched it, and it worked fine after that. I didn't drive the car for close to a month, and then today I noticed this. Could rust have built up inside the radiator and partially a coolant passage somewhere?
Old Feb 24, 2006 | 10:43 PM
SiR Inspired ED7's Avatar
Default Re: B16 overheating when car is not moving. (Chief Wenceslaw)
Have you replaced your Thermostat?
That Might Be the problem.
Your Radiator hoses, Check the bottom one, i believe if the bottom one is cold, the thermostat isn't good.
Thermostat price - about 8 bucks. to replace is easy
let us know how things turn out
Old Feb 24, 2006 | 11:22 PM
Reelizmpro's Avatar
Are you 100% sure the fan is working? If you're not losing any coolant then it may be the thermostat although not likely. I often find that overheating is due to causes other than thermostats, like coolant leaks, faulty pressure caps, non operating fans, etc.
Old Feb 25, 2006 | 03:38 AM
4thgenhtch's Avatar
Default Re: B16 overheating when car is not moving. (Reelizmpro)
Yea check that fan out for real...
Old Feb 25, 2006 | 07:33 AM
91civicEX's Avatar
are you low on coolant?
Old Feb 25, 2006 | 07:35 AM
ghost_ryder35's Avatar
Default Re: B16 overheating when car is not moving. (91civicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicEX &raquo;</TD></TR><TR><TD CLASS="quote">are you low on coolant?</TD></TR></TABLE>
Old Mar 4, 2006 | 11:44 PM
Default Re: B16 overheating when car is not moving. (ghost_ryder35)
Nope, fan works great, just filled up coolant, and the cap has plenty of pressure under it. No radiator leaks, nothing.
drshottest718
24
Jun 25, 2016 07:09 AM
EGcivic_95
31
Jan 29, 2011 06:09 PM
HaPRoLo
Oct 22, 2007 10:08 AM
spock_rocker
Jun 6, 2005 03:32 PM
xZeler8
Nov 26, 2004 10:47 PM
