DOOR HELP!
Old Feb 24, 2006 | 06:59 PM
nbcivic's Avatar
Default DOOR HELP!
My drivers door feels loose. Like, when i pull on the arm rest from the inside, it feels kinda loose, and when i close the door, the whole thing just feels loose. Like not from the hinges, but the padding and stuff, including the manual window handle, it's loose as well, but the window still works, any suggestions on how i could tighten this door?
Old Feb 24, 2006 | 07:05 PM
chilly.'s Avatar
if its just the paneling use some type of adhesive
Old Feb 24, 2006 | 07:08 PM
nbcivic's Avatar
Default Re: (J-TIZZ)
i don't think it is just the panneling, cause the whole thing just seems loose, are there some screws i could tighten?
where would i apply adheasive?
Old Feb 24, 2006 | 07:40 PM
EL Vap133's Avatar
Default Re: DOOR HELP! (nbcivic)
Take the door panel off and see if anything is loose/broken.
Old Feb 25, 2006 | 03:53 PM
nbcivic's Avatar
Default Re: DOOR HELP! (EL Vap133)
idk how to do that, can you give me some hints?
Old Feb 25, 2006 | 04:08 PM
AfrikanBush's Avatar
there are i think 3 screws in the panel, 1 in the door handle on the armrest, on under the inside latch and one on the panel itself near the dash. once you take oun the screws remove the trim on the arm rest and around the latch. should then just slowly pull off.
Old Feb 25, 2006 | 04:14 PM
nbcivic's Avatar
Default Re: DOOR HELP! (AfrikanBush)
sweet. thx i'll try it.
XViEtBoiX
Honda Civic (2001 - 2005)
Dec 16, 2006 10:38 AM
businessmanph
Oct 30, 2005 10:45 PM
C2daIzZle
Sep 8, 2005 10:01 AM
206civic
Jan 8, 2005 11:43 AM
babyviper97
Jan 10, 2003 05:14 AM
