30,000 tune-up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mellowhead »</TD></TR><TR><TD CLASS="quote">What would you guys suggest for a 30,000 mile service. 04 that is.
well do the obvious things, check your fluids, change the oil if its due. Also check your spark plugs, air filter and cabin cabin filter thats located on the passanger side directly behind the battery also its behind the fire wall. You have to pop off a small section of the vents located at the bottom of your windshield....phew
</TD></TR></TABLE>well do the obvious things, check your fluids, change the oil if its due. Also check your spark plugs, air filter and cabin cabin filter thats located on the passanger side directly behind the battery also its behind the fire wall. You have to pop off a small section of the vents located at the bottom of your windshield....phew
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco »</TD></TR><TR><TD CLASS="quote">valves
</TD></TR></TABLE> what would need to be checked with the valves. Thanks
spark plugs do not need changing at 30k, just pull them and take a look. i highly highly doubt they need to be changed
things you must do:
Oil
Transmission Fluid
Brake Fluid
Differential Fluid
Coolant
Air Filter
In Cabin Filter
Check tires, suspension components, wires, hoses. See if anything is wearing oddly. Lubricate areas as necessary
things you must do:
Oil
Transmission Fluid
Brake Fluid
Differential Fluid
Coolant
Air Filter
In Cabin Filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mellowhead »</TD></TR><TR><TD CLASS="quote">What plugs do you guys recommend for the S. I want some good plugs..Wires Too. Have to be good and preferably yellow.
you dont need wires because, they use individual coils
</TD></TR></TABLE>you dont need wires because, they use individual coils
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mellowhead »</TD></TR><TR><TD CLASS="quote"> what would need to be checked with the valves. Thanks
gap
</TD></TR></TABLE>gap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco »</TD></TR><TR><TD CLASS="quote"> gap
Got It
</TD></TR></TABLE>Got It
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant »</TD></TR><TR><TD CLASS="quote">spark plugs do not need changing at 30k, just pull them and take a look. i highly highly doubt they need to be changed
things you must do:
Oil
Transmission Fluid
Brake Fluid
Differential Fluid
Coolant
Air Filter
In Cabin Filter
Check tires, suspension components, wires, hoses. See if anything is wearing oddly. Lubricate areas as necessary</TD></TR></TABLE>
that pretty much sums it up right there. other than that just check and top off all other fluids
things you must do:
Oil
Transmission Fluid
Brake Fluid
Differential Fluid
Coolant
Air Filter
In Cabin Filter
