h22 in 95 hatch
Old Feb 24, 2006 | 04:25 PM
msinsky14's Avatar
Default h22 in 95 hatch
what modifications to an h22 and the civic are needed to run it in a 1995 dx?.............how come its more expensive to buy a b16 then and h22
Old Feb 24, 2006 | 04:29 PM
PhoebeusFenix's Avatar
best place for this is the hybrid forum. But ill help!
Youll need a mount kit, custom made axles, and a way to rig up the cable shifter into your interior, as of right now, your transmission is hydraulic.
Either that or buy a h2b kit and then you can use the mounts it comes with, and b series axles, and tranny.
The h22 swap is more expensive when you consider you will need to pay $450 for a mount kit, and $500 for custom made axles. Either that or the h2b kit is another $1000.
So the b16 ends up being cheaper. Plus you dont have to butcher your interior to get the cables for the shifter in.
Old Feb 24, 2006 | 04:41 PM
ntrider's Avatar
Default Re: h22 in 95 hatch (msinsky14)
I read on here about a kit that allows you to use a b series tranny with the h22 block. This way you are able to stay hydraulic and not have to do any fab work. Also you will be able to use b series axles. hopefully others have heard about this and add their .02 cents
Old Feb 24, 2006 | 04:43 PM
msinsky14's Avatar
Default Re: (PhoebeusFenix)
so......what engine would give me the most bang for the buck?.......im going to get it installed professionally, but just looking for price of the parts
Old Feb 24, 2006 | 05:12 PM
Well, if I had the money, I would go h22 probalby if I was leaving it n/a. For the bang, having a mid-12 second hatch stock is a nice thing.
I am wanting to go boost however and from what I have researched, the b16 is more reliable at the moment in terms of boost.
Also I will be using it as a daily driver so I will put a ls fifth gear in the b-series sometime so I can have a more comfortable cruising car.
jdm.ejone
Jul 23, 2007 04:24 PM
EkPudge
Jul 9, 2006 03:59 PM
msinsky14
Feb 22, 2006 06:51 PM
ludespeeder
Oct 8, 2002 09:20 AM
cccya
Apr 25, 2002 04:19 PM
