Will this help my 1/4 time?
Old Mar 28, 2002 | 07:54 PM
93vteclude's Avatar
Default Will this help my 1/4 time?
i ran 15.0 with my stock rim (heavy a$$ 92-93 si rim 22lbs each) will it help if i switch to 14'' accord steel rim . I weight them both 92 si rim with tire each 40lbs, accord steel rim 14'' 30-32 lbs. my friend with 95 gsr he has 4 steel civic rim 14'' ran 14.9 1/4 some one just post he said 1lbs on the tire=50lbs car weight
thanks
Old Mar 28, 2002 | 07:58 PM
NONKonformyst's Avatar
Default Re: Will this help my 1/4 time? (93vteclude)
It really wouldn't hurt to try. I'm not sure if it would take any more than a few milliseconds off your 1/4 mile time with those weight differences. You would definetely notice a huge difference if you went to an ultra-lightweight wheel from those stockers.
Old Mar 29, 2002 | 04:35 AM
bgod's Avatar
Default Re: Will this help my 1/4 time? (95redLUDE)
ultralight wheels or not. tires also factor into weight.
going from 40lbs. to say 32-30lbs. is a huge, huge difference. you could possibly see a couple of tenths if you can take full advantage of it.
that's why i switched to 94-96 prelude wheels on my 93 vtec.
Old Mar 29, 2002 | 05:48 AM
tec-9-7's Avatar
Default Re: Will this help my 1/4 time? (bgod)
If the new wheel/tire combo is shorter than the old one, it will also help your 1/4 mile times by effectively lowering your final drive ratio.
Paul
Old Mar 29, 2002 | 06:03 AM
93delsol's Avatar
New User
taking one pound of rotating mass is equal to taking 8 pounds of non-rotating mass.
Old Mar 29, 2002 | 07:17 AM
93vteclude's Avatar
Default Re: Will this help my 1/4 time? (93delsol)
thanks all i think it's time to get some lightweight wheel
Old Mar 29, 2002 | 09:18 AM
Honda318dx's Avatar
What size tire was on the accord wheel? Also, I doubt the 14" wheel will fit over your 11.1" brakes
wfocrx
May 27, 2014 04:17 PM
michaelprice83
Dec 14, 2008 08:12 PM
Accord-Guy
May 24, 2007 04:00 PM
y2kferari
May 8, 2006 03:27 PM
Sinner
Sep 14, 2003 05:48 PM
