Blinker Problems/
Old Mar 25, 2002 | 12:16 PM
cr2501129's Avatar
Default Blinker Problems/
I have a 92 prelude. I just put a new Andy's Auto frount bumper. The bumper does not have cut outs for blinkers. I thought I could just make my corner lights into blinkers. I want the corners to have constant power when my headlights are on and I want them to blink also. Had no problem with the passenger side. I can only get the driver side corner to blink, but it will not run constantly when the headlights are on. So I checked the other leads for the stock blinkers: I have 6 volts on one of the leads? I am stumped . Can anyone recomend what I should do? I think I might have broken a circuit somewhere? I do not have a helms manual, and the CHILTONS is useless. Can someone please help me!
I can be reached at: cr2501129@aol.com or prelude1129@aol.com
Old Mar 25, 2002 | 01:01 PM
Greyout's Avatar
Default Re: Blinker Problems/ (cr2501129)
you should wire the bulb that used to be on the bumper (on the side, the small wedge bulb) to the upper one.
Old Mar 25, 2002 | 06:39 PM
ELUD THS's Avatar
New User
Default Re: Blinker Problems/ (JDM LUDE)
you can do it that way or get a relay,.
Old Mar 26, 2002 | 05:20 AM
cr2501129's Avatar
Can you tell me how I would go about checking,or replacing the relay? I can get the light to blink, but I cant get it to stay on as a running light, like the passenger side corner light. Also, I checked the leads that were going to the stock blinker in the old bumper. No power on one, and the other only has 6 volts? Where is the fuse for all the driver side blinkers? I checked the fuse box and there does not seem to be any blown fuses. I have tryed to run another turn on power lead to the blinker, but when I do that, the blinker will no longer blink?
Old Mar 28, 2002 | 11:59 PM
jlude92's Avatar
i also have a 92 with that bumper. my corners (headlight corners) stay on with my headlights and also work perfectly as blinkers. but i bought my car with that already on there so im not sure how you get that to work. but the wiring and everything seems to be stock and not messed with.
Old Mar 29, 2002 | 10:11 AM
H22g2Integra's Avatar
All you have to do is take the signal wire that is the one that goes to 12v when signalling and put it on the ground wire of the park light bulb. When you turen your head lights on the light will come on and when you signal the wire you connected to the ground side make the light flash so you have both functions. No relay is required. it works cherry
Old Mar 29, 2002 | 12:25 PM
cr2501129's Avatar
Default Re: Blinker Problems/ (H22g2Integra)
Thank you so much for the info. I will give it a try tomorrow!
lilman4o8
Aug 29, 2007 05:23 PM
eeeKs
May 27, 2004 02:33 AM
specie
Dec 9, 2003 07:55 PM
rasta420
Nov 23, 2002 06:13 AM
dom93hatch
Nov 16, 2002 02:13 PM
