Help with Starter Installation
Old Feb 24, 2006 | 01:28 PM
S2KBAR's Avatar
Default Help with Starter Installation
Hello, I recently purchased a remanufactured starter for my del sol VTEC (b16a3) but after bolting it on and making start attempts it sounds like the starter shaft is grinding against the flywheel. I don't think its the wrong starter because it bolts perfectly to the block and neither a single cam non Vtec and Vtec starters will fit. So, I'm wondering if there are extra steps other than bolting the starter in the right place and connecting all the wires properly. Your opinions will be greatly appreciated.
Old Feb 24, 2006 | 01:33 PM
wwang924's Avatar
Default Re: Help with Starter Installation (B16 Turbo Del Sol)
Logically, i has to be either the wrong part if it seems to fit from the outside, or something is wrong with your flywheel.
Old Feb 24, 2006 | 01:37 PM
S2KBAR's Avatar
Default Re: Help with Starter Installation (wwang924)
Well, the original starter worked fine after it died. I recently changed my clutch and the flywheel is perfect.
Is there any other car that might use the same starter?
G60
Oct 13, 2020 12:58 PM
Whiteranger
May 27, 2013 06:39 AM
si1992
16
Jul 18, 2012 02:01 PM
h22a_black
Feb 13, 2008 06:12 AM
383chevy
Jan 25, 2007 07:58 PM
