civic cluster back light not working!!!
hey i have a 93 civic dx, and the light in the cluster isnt working( the ones that light up at night), is there like a fuse that has needs to be changed? any ideas, there is this fuse which is for instrument lightning, but that same fuse feeds throght to the tail lights too, but tail lights are working. and i checked the cluster with a Ohm meter and it seems like the conction green board on the back seems to be okay.
so im not sure. maybe its from the wires?
no idea
anyone?
no idea
anyone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">does your dash lighting work when you switch on the lights?
if your dimmer dies the cluster will not light up.</TD></TR></TABLE>
the dash lighting doesnt work either. the last owner of the car, pulled a 12V wire and connected these blue bulbs to the cluster and the climate control.
I had the same problem. It is really common for the dimmer switch to be intermittent or not work at all. I took mine apart and tried to figure out how to fix it but just gave up and bought another one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdmEFboy »</TD></TR><TR><TD CLASS="quote">dude i have the same problem but my climate control lights aren't working either...could this also be the dimmer switch??</TD></TR></TABLE>
yah mine either.
yah mine either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg »</TD></TR><TR><TD CLASS="quote">I had the same problem. It is really common for the dimmer switch to be intermittent or not work at all. I took mine apart and tried to figure out how to fix it but just gave up and bought another one.</TD></TR></TABLE>
where should i get the dimmer switch from?
maybe junk yard?
or how about honda?, how much could it be there?
maybe junk yard?
to check to see if your dimmer is bad.
pull out the dimmer switch
note the three wires in the back of it. (red, black and red/black) - (red/black means red with a black stripe)
take a jumper wire and splice the red wire and the black wire together. leave the red/black wire alone.
after that turn on the lights, your cluster and dash should light up at full brightness.
dimmer switches can found at a local junk yard, ebay or the marketplace on here.
i pulled out the dimmer switch and found out that this is the problem, the other owner of the car had the wires goin to the dimmer cut and used another wire to it which was pulled into the cluster and to these bulbs that where costum fitted into the cluster it self.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">to check to see if your dimmer is bad.
dimmer switches can found at a local junk yard, ebay or the marketplace on here.</TD></TR></TABLE>
ill try conecting the red and the black togather and see if it work, if it does than im not gona bye another dimmer switch, cause i always leave it to the max light output.
thanks bro
thanks bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alispoon »</TD></TR><TR><TD CLASS="quote">
thanks bro
i tried ur thing and didnt work exactly but anyways i found a 12V elctrisity runing throw this wire back there and took that 12V and used it to connect it to the wire on the plug which was seppost to feed the circuit to light up the background.
one thing is that i cant find out wat happend to the blinkers on the in the cluster, they dont work anymore after i pulled this project, any ideas for that now, i checked the fuses in the fuse box, didnt find it, where is that machinesim that makes that tick tick sound?
thanks bro
</TD></TR></TABLE>i tried ur thing and didnt work exactly but anyways i found a 12V elctrisity runing throw this wire back there and took that 12V and used it to connect it to the wire on the plug which was seppost to feed the circuit to light up the background.
Shimakid12
Aug 11, 2009 07:05 PM
mortificationrock
Mar 5, 2008 11:19 AM
lluks_844
Jun 1, 2007 05:01 PM
derekdunham
Jul 23, 2005 05:16 AM
