B16A2 --> 92-95 Civic ... what parts needed?
Old Mar 28, 2002 | 07:30 PM
redlineintegra's Avatar
Default B16A2 --> 92-95 Civic ... what parts needed?
Hi guys,
Need help .. I am installing a JDM B16A2 into an EG .. will the stock mounts swap over to the JDM motor? And what motor is the US equivalent, to buy OEM Honda parts (timing belt, water pump, etc) for it?
TIA.
Old Mar 28, 2002 | 09:24 PM
Redline130's Avatar
Default Re: B16A2 --> 92-95 Civic ... what parts needed? (redlineintegra)
Use parts off of a Del Sol vtec. Same motor essentially.
Old Mar 28, 2002 | 09:32 PM
Default Re: B16A2 --> 92-95 Civic ... what parts needed? (cyber13)
Thanks guys.
But can I use the EG motor mounts, swapped onto the B16A2?
Old Mar 28, 2002 | 09:50 PM
KayOs's Avatar
You can use all your stock mounts except the rear tranny mount. You will have to get one from a 3rd generation integra for the swap. You may also have to get the timing belt mount as well.
good luck.
Old Mar 28, 2002 | 10:00 PM
Default Re: B16A2 --> 92-95 Civic ... what parts needed? (KayOs)
Thanks all, much appreciated.
Old Mar 28, 2002 | 10:03 PM
Soku1kcivic's Avatar
you should use integra GSR motor mounts and the motor should fit right in if your EG is a SI then your set with the wiring and the VTEC!!
Old Mar 29, 2002 | 05:36 AM
bigblockEG's Avatar
I'm pretty sure that your going to need all vtec mounts. I would go with the del sol mounts as well. I think that the top tranny mount is going to come from your civic. You can use the mounts that are undert he frame rails in the front from your civic and the rubber part of the mount on the sub frame from the civic. You are going to need the back bracket from the del sol. Not 100% but pretty sure.
Old Mar 29, 2002 | 08:14 PM
bojangs's Avatar
New User
Default here..
don't thank me.. thank katman..
and when buying parts at the dealership for your motor get 94 del sol vtec stuff..
Old Mar 30, 2002 | 12:55 AM
whoa .. thanks guys!!! are there any more diagrams like that to refer to? :D
Also, can I use the axles from the B16A2 .. was told by a local shop to use 94+ Integra axles and linkage .. but he also said I could use the stock EG mounts hmm....
Old Mar 30, 2002 | 10:39 AM
90accord1's Avatar
Default Re: here.. (bojangs)
if you order a swap all the mounts that come on it you can use, unless its a first gen motor. if its a 2nd gen not b16a2 as that would bne 97-00 del or civic si motor, the mounts will bolt right up that come with it. as well as the shift linkage they should include.
Old Mar 30, 2002 | 03:30 PM
crx-mike's Avatar
Default Re: B16A2 --> 92-95 Civic ... what parts needed? (94hondahybrid)
There isnt a us equivalent. I believe there is a Canadian equivalent that came in the 1.6EL. If I remember correctly we never got the SiR, but Canade did (just called the Si) so there are many parts for it available. just gotta look. There are many parts off of other B-series motors that work however.
this is a little off topic, but just to clarify, the 1.6EL came with a SOHC VTEC.
Mike
Old Mar 30, 2002 | 09:56 PM
Default Re: B16A2 --> 92-95 Civic ... what parts needed? (crx-mike)
Ok, I want to double check, cause this motor swap is for a friend.
GOING INTO A 1992 Canadian Civic coupe:
JDM B16A2 (170 hp, DOHC VTEC) .. not the JDM B16A3
- 3G Integra axles
- 3G Integra linkage
- 3G Integra mounts (except tranny mount)
- stock Civic wiring harness
As I understand it, the stock or JDM axles will not work, the stock linkage on the CDN Civic will not work, the stock CDN Civic mounts will not swap over, and the stock wiring harness will work, with added wiring.
Old Mar 31, 2002 | 09:09 AM
Old Mar 31, 2002 | 02:19 PM
can someone answer my last question? TIA guys!
Old Mar 31, 2002 | 05:42 PM
JV's Avatar
JV
Who?
http://hybrid.honda-perf.org/faq/section02.html
Try this.........
Old Mar 31, 2002 | 06:22 PM
Default Re: B16A2 --> 92-95 Civic ... what parts needed? (JV)
uhhh .. THANKS .. hehe (newbie) :D
kpjo4
Mar 19, 2010 10:52 PM
Urugly
Apr 5, 2006 12:43 PM
gear
Oct 10, 2003 07:30 PM
vtec69
May 28, 2002 08:24 AM
