hf crx radiator problems need fix
I have a stock hf crx that i got as a shell and put the stock motor in for a daily driver. the car is all stock under the hood. no performance goodies at all.
the problem I have is the drain plug will leak and drip until the radiator is dry.
I have put teflon tape on the drain plug threads and seemed to help but after I ran the car for a while it started again. I havent replaced the o ring becase it dosent look worn.
should i replace the drain plug or thnk of something else to do?
i came for help because its boggling my mind.
what do you guys think?
well radiators are cheap on http://www.radiators.com I would just buy a new one. But if you are intent on fixing it I would replace the drain plug and see if that fixs it. It is a cheap fix, but I think the $80 for a new one is a good deal!
if i get a radiator its going to be a full race aluminum.
i will try to get a o ring for it.
auto zone said they would have to order one.
been working on my buddys integra that we took the motor out and i am gettin the four wheel disc for my crx. i have been real busy.
tercelrcr
Jan 8, 2012 02:35 PM
1990 CRX Si
Dec 17, 2005 06:37 PM
d16dcoe45
Nov 20, 2005 01:20 PM
