What are all the different types of gaskets do i need for a rebuild?
Old Mar 28, 2002 | 06:59 PM
StinkyTofu's Avatar
Default What are all the different types of gaskets do i need for a rebuild?
Hey guys, i'm getting cams, pistons installed for my car. I was wondering what was eveything i needed to do this install? Friend told me to go to kragen to get some sort of gasket "kit".
So i need new cam seals, valve cover gasket, head gasket, oil pan gasket... do you guys know what else i need?
Old Mar 28, 2002 | 07:11 PM
JSIR's Avatar
New User
Default Re: What are all the different types of gaskets do i need for a rebuild? (StinkyTofu)
just go to Honda and by an upper gasket kit, will include all the gaskets you need. There is also a lower gasket kit that has the oil pan gasket, and the oil pick up screen gasket, but those two can be reused at least once safely. So I would just get the upper gasket kit. The kit is cheaper than buying all of them individually even if you don't use them all. hth.
Joey
Old Mar 28, 2002 | 07:14 PM
MackSpeed-616's Avatar
be sure to replace the alternator gasket and the distributor fluid
Old Mar 28, 2002 | 07:36 PM
GokuSSJ4's Avatar
always use oem gaskets
Old Mar 28, 2002 | 07:41 PM
StinkyTofu's Avatar
Default Re: What are all the different types of gaskets do i need for a rebuild? (Spoon1)
For my headgasket, is it ok if i go with spoon? Or should i go with honda? Thanks for the info guys. One last info, do you guys happen to know how much the upper kit is?
Old Mar 28, 2002 | 07:54 PM
AlphaKennyWun's Avatar
Looks like you still need spark plug gaskets, crank o-ring seals and cam o-ring seals. Just ask for them at Honda they know what to looks for.
dth0ng69
Jul 14, 2009 08:28 PM
93sivtec
May 10, 2009 05:00 AM
BlueLude84
Feb 4, 2007 11:14 AM
Btothe3rdDegree
Aug 20, 2003 06:26 PM
B20-T
Feb 16, 2003 05:44 PM
