B16 swap
Old Feb 24, 2006 | 06:32 AM
niffer_marie's Avatar
Default B16 swap
I'm getting a DOHC DelSol shell and buying a B16A2 out of a 2000 Si. Would the stock DelSol motor mounts be fine for this? Nobody in my area has done much work with DelSol's so we're all kind of dumbfounded by it. And I'd have to re-wire to OBD1, correct? I'm pretty sure I know all of this...I'd just thought I'd verify. Thanks!
Old Feb 24, 2006 | 06:44 AM
philosofy1's Avatar
Default Re: B16 swap (niffer_marie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niffer_marie &raquo;</TD></TR><TR><TD CLASS="quote">I'm getting a DOHC DelSol shell and buying a B16A2 out of a 2000 Si. Would the stock DelSol motor mounts be fine for this? Nobody in my area has done much work with DelSol's so we're all kind of dumbfounded by it. And I'd have to re-wire to OBD1, correct? I'm pretty sure I know all of this...I'd just thought I'd verify. Thanks! </TD></TR></TABLE>
your best bet is to order the obd1 conversion harness from hasport, it'll make wiring easy and less of a mess.
as far as for the mounts. i believe everything should bolt up except the driver(left)side mount. you will just need a mount for that side off any 92-95 civic or 93-96 del sol. make sure it has the 2 mounting holes. some part stores may have them listed incorrectly. atleast the ones where i live.
dwils
14
Apr 21, 2011 02:00 PM
96f22b2
May 10, 2009 02:32 PM
slowej1
10
Jun 13, 2007 05:13 PM
perix84
Dec 27, 2006 07:16 PM
bennyhonda7
May 26, 2005 06:50 AM
