H22A
So i'm getting a complete H22A swap, well not fully because it is missing injectors and ECU but I am putting in new cams, valve train and pistons as well as rods. any ideas forinjectors I was thinking 370's but what about the ECU...
stock injectors are 345s in the obd1 prelude. and usually you don't need to upgrade those for an all motor unless you are going all out. I would only get the 370's if you get them cheap and you have something to tune it with.
stock computer is the p13 for obd1.
what pistons are you putting in? just remeber that because of the sleeve material you can only use stock. (Or mahale gold series)
3gLudeH22A
Jun 9, 2002 06:25 AM
