Buying a B16A1 What ECU to go with?
Old Feb 23, 2006 | 09:45 PM
Xgen's Avatar
Default Buying a B16A1 What ECU to go with?
I am buying a first gen B16 from a friend, it does not come with an ECU and I will be swapping it in to my other car which is a 94 eg coupe si with vtec already wired up, my first question is, what ECU should I go with, I will be using the distributor from a OBD1 integra so everything will still be OBD1.
My second question is, does the vtec solanoid have the same connector from OBD1 to OBD2?
Any info is appreciated, thanks guys.
Old Feb 23, 2006 | 11:37 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Buying a B16A1 What ECU to go with? (SLOW guy)
OBD1? Used a chipped P28 for DOHC VTEC application, or use a USDM or JDM P30 for a plug and play operation.
Old Feb 23, 2006 | 11:48 PM
viper1984's Avatar
I thought that first gen b16's aren't recommened for Eg....??
Old Feb 23, 2006 | 11:58 PM
BlueIntegraBoy's Avatar
Default Re: Buying a B16A1 What ECU to go with? (Xgen)
P30
Old Feb 24, 2006 | 01:22 AM
salesmonkey's Avatar
Default Re: (viper1984)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viper1984 &raquo;</TD></TR><TR><TD CLASS="quote">I thought that first gen b16's aren't recommened for Eg....??</TD></TR></TABLE> lol
Old Feb 24, 2006 | 04:18 AM
Phantastic's Avatar
Default Re: Buying a B16A1 What ECU to go with? (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">OBD1? Used a chipped P28 for DOHC VTEC application, or use a USDM or JDM P30 for a plug and play operation.</TD></TR></TABLE>
Old Feb 24, 2006 | 09:39 AM
Xgen's Avatar
Who told you that?
Old Feb 24, 2006 | 09:42 AM
entityzero's Avatar
Default Re: (Xgen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xgen &raquo;</TD></TR><TR><TD CLASS="quote">
Who told you that?</TD></TR></TABLE>
1st gen B16A Sir/Xsi has a cable transmission. You would either have to convert over or get a hydro tranny for it. You can use chipped P28 or P30 ecu.
Old Feb 24, 2006 | 10:35 PM
mtber's Avatar
You could run a chipped obd1 ecu for the b16
Check out https://honda-tech.com/zerothread?id=1258100
Old Feb 24, 2006 | 10:51 PM
nello a.'s Avatar
p30
Old Feb 24, 2006 | 11:17 PM
EG6 PSI's Avatar
Default Re: (nello a.)
could always use an OBD1 P72 also
Old Feb 25, 2006 | 06:24 AM
[Eg.6]LiLbOy916's Avatar
My Folks had the same motor ..they ran p28 Ecu with it
Old Feb 25, 2006 | 06:43 AM
mycivic93dx's Avatar
ihave a b16 swap in my 93 dx coupe a unchipped p28 will robb u of power rpm's max at 7200 use a p30 or above.
Old Feb 25, 2006 | 07:42 AM
99CivicSiBrian's Avatar
B A N N E D
If you get a good deal, then I'd recommend it. If you're buying a swap from an importer, you may as well save up to buy the SIR-II 2nd gen, OBD-1 swap because it'll save you the hassle of having to use a cable-to-hydro tranny conversion kit, different distributor, drivers side post, rear tranny bracket, and tranny mount. Oh yeah, don't forget the 1st gen linkage doesn't work, and the stock throttle cable won't work. And the VSS will have to be swapped, but thats not too big of a deal. You'll also have to chip a p28, or purchase a p30 to make it all work.
Cliffs notes- IF 1st gen B16 is good deal, then get it, but if not you'll spend the same amount in parts if you would have just bought 2nd gen in the 1st place.
dsmh8tr
Aug 27, 2008 07:13 PM
asocallocal
May 30, 2005 10:11 PM
mrkdky
Dec 24, 2004 01:37 PM
DesertCivic
Nov 5, 2004 10:31 AM
