Killing caps and rotors 90 STD
Old Feb 23, 2006 | 09:26 PM
seajay's Avatar
Default Killing caps and rotors 90 STD
90 civic hatch STD bogging engine = new plugs = fixed it for an hour. the ECU spits out 8 and 16 I've replaced the rotor but the distributer pins keep breaking at around 3000rpm
how? cold, broke, and ignorant
FYI All wires severed on the driver door
Old Feb 23, 2006 | 09:32 PM
onepoint6i's Avatar
Default Re: Killing caps and rotors 90 STD (seajay)
you definetly have broken wires somewhere
8=crank angle sensor in distributor
16= injector circuit problem...
Old Feb 23, 2006 | 09:51 PM
bigcalidave's Avatar
You are actually breaking the contacts off in the distributor?? Your cam is moving, need new bearings or a new head.
Old Feb 23, 2006 | 10:00 PM
seajay's Avatar
Default Re: (bigcalidave)
ok, i am an idiot, but i have time and a friend; so could you ballpark cost diy?
It only has to run for a couple months, and i'm runnin out of cash
Old Feb 24, 2006 | 11:32 AM
Perfectionist's Avatar
try an OEM cap/rotor. The center pin is spring loaded. I really can't see how it would just break.
As for the code 16... the ECU sets that whenever there is a break in the electrical path for the injectors. The main relay is a prime suspect in this case. One half powers the fuel pump, the other half the injector circuit.
Old Feb 24, 2006 | 11:41 AM
jlicrx's Avatar
Default Re: (seajay)
the bearings in the distributor are shot causing the shaft to wobble which is why it has code 8 and rotor keeps hitting the cap
Old Feb 24, 2006 | 12:09 PM
ghost_ryder35's Avatar
Default Re: (jlicrx)
^^^^^^^^^^^^^^^^^ Damn that guy is smart
Old Feb 24, 2006 | 01:05 PM
Donkey85's Avatar
Default Re: (ghost_ryder35)
i have a spare std dizzy if u want it 65 shipped pm if u want it
Old Feb 24, 2006 | 03:31 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">the bearings in the distributor are shot causing the shaft to wobble which is why it has code 8 and rotor keeps hitting the cap </TD></TR></TABLE>
I just got mine back from the shop due to that...
Atomic1
Mar 19, 2010 05:12 PM
wkiltz
May 1, 2008 04:04 PM
Japanese1.6
Apr 10, 2005 08:42 AM
G2DAteg
Apr 5, 2005 11:32 AM
draco067
Jun 21, 2003 12:23 AM
