3rd gear grinding.. help
Old Feb 23, 2006 | 09:03 PM
VTECcnIT's Avatar
Default 3rd gear grinding.. help
i cant pop into 3rd gear when im accelerating.. it grinds like crazy. what are things i can do to fix this problem .. and cost?? help
Old Feb 23, 2006 | 09:29 PM
IN VTEC's Avatar
Default Re: 3rd gear grinding.. help (VTECcnIT)
Do the usual....check fluid level, change fluid to Honda MTF or GM syncromesh, with the last resort being replace the 3-4 synchro set, 3rd gear, and maybe the 3-4 shift fork as well.
The longer you let it go grinding into 3rd, the greater the damage will be to the synchro sleeve and 3rd gear. Find a solution to keep it from grinding ASAP to keep it from escalating to a more expensive repair, if it isn't already at that point.
I think the cost for a 3-4 synchro set is around $200 to $250, shift forks are usually $50 to $60, and any single gear are anywhere from $55 to $80.
Old Feb 23, 2006 | 10:28 PM
VTECcnIT's Avatar
Default Re: 3rd gear grinding.. help (IN VTEC)
if its just 2nd to 3rd gear grind and the rest are good, how many synchros do i need?
sorry ima noob trying to learn
Old Feb 23, 2006 | 11:16 PM
IN VTEC's Avatar
Just the 3-4 synchro set and a 3rd gear.
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECcnIT &raquo;</TD></TR><TR><TD CLASS="quote">if its just 2nd to 3rd gear grind and the rest are good, how many synchros do i need?
sorry ima noob trying to learn</TD></TR></TABLE>
You'll need the 3-4 sleeve set. 3rd og 4th syncros only come as a pair.
Part# 23623-P21-315 here:
http://www.acuraparts247.com/s...ch=no
You should change that ASAP because the longer you drive with grinding the more wear you'll put on the 3rd gear. If your unlucky you might have to change the gear as well.
Old Feb 24, 2006 | 12:03 AM
Takumi Fujiwara's Avatar
Default Re: 3rd gear grinding.. help (Pompiuses)
Open it up. Could be a synchro, could be one of those fork things (I don't know the correct name for it)... but opening it up will be the only positive way to check.
Old Feb 24, 2006 | 02:08 PM
Ryan_C's Avatar
Default Re: 3rd gear grinding.. help (Takumi Fujiwara)
These are some nice good answers guys! I will probably have some more detailed questions once I open up my extra transmission. This should happen soon.
Ben, you will remain close to the top of my list for if I get myself in trouble. What have you been doing lately? Heading to Expo 6 this year? Really really close to home this time.
Old Feb 24, 2006 | 06:21 PM
IN VTEC's Avatar
Default Re: 3rd gear grinding.. help (Ryan_C)
No Expo for me this year. I've got too much time vested into work. I'll just be attending Formula One, Indy 500, and One Lap of America.
Old Feb 24, 2006 | 06:57 PM
IW03's Avatar
Syncro grinding in 3rd Gear ay. Oi dude, if u wana temporary relieve for a while, use Auto Tranny Fluid man. Trust me it works, i wont do more damage, it works the same as GM Syncromesh fluid.
Celica GT4 (St185)'s are common with gearbox syncros wearing especially in 2nd and 3rd, and i owned one. They are a bitch to fix, labour wise. And as a temporary relief i used Auto Gear box fluid, until i sold the car. People on the forum that i use to talk to about the gearbox all used it and told me to do it as a temporary relief. So give that a go man
PsychoSiRex
Honda Civic (2006 - 2015)
Sep 16, 2009 09:15 PM
Evil_Ek
Feb 9, 2006 08:33 AM
bustedasscivic
Nov 16, 2003 09:59 AM
gsrteg93
Apr 30, 2003 11:07 AM
