d15b7 intake manifold swap Q
Old Feb 23, 2006 | 08:17 PM
moores55's Avatar
Default d15b7 intake manifold swap Q
i have a d15b7 and i am being offered a y8 intake manifold for 40 bucks. do yall think it is worth it and is it a good price. also will i need anything for the swap besides new gaskets.
Old Feb 23, 2006 | 08:41 PM
96dxpower's Avatar
Default Re: d15b7 intake manifold swap Q (moores55)
why not keep your OG one?
Old Feb 24, 2006 | 09:47 AM
moores55's Avatar
Default Re: d15b7 intake manifold swap Q (96dxpower)
im wanted to know if i would benifit from the longert runners and whatnot and if there might be a 1or2 hp gain
Old Feb 24, 2006 | 12:28 PM
moores55's Avatar
bump for info
Old Feb 24, 2006 | 12:34 PM
snatch's Avatar
You should pick it up. Everything should work fine, maybe with slight modification. You will need the Y8 throttle cable bracket also. Other than that you should be good to go. I don't think you'll need the Y8 throttle body, because the B7 intake manifold is the same shape as the Y8, just different design. The Y7 manifold has the downdraft throttle body...gay.
Search for some DIY's on here, I know they exist. Either a Z6 or a Y8 manifold would greatly help.
Old Feb 24, 2006 | 01:11 PM
Donkey85's Avatar
Default Re: d15b7 intake manifold swap Q (******)
somebody correct me if im wrong but isnt that the best flowing im out of all the d series
Old Feb 24, 2006 | 01:17 PM
moores55's Avatar
Default Re: d15b7 intake manifold swap Q (Donkey85)
it is but i want to know if it will bolt up to my b7 head.
Old Feb 24, 2006 | 06:39 PM
Chrisfrom1986's Avatar
any d series manifold (either intake or exhaust) will bolt up to any d series head.
Old Feb 25, 2006 | 06:16 PM
snatch's Avatar
Default Re: (chrisfromda909)
Correct. It will bolt up to your B7 head.
Libertariat
Feb 26, 2007 06:00 AM
suspendedHatch
Sep 18, 2006 05:00 PM
redciviclx14
Jun 28, 2003 11:31 PM
RacerBoy
May 14, 2003 04:55 PM
photonjedi808
11
Feb 18, 2003 10:36 PM
