wiring up obd1 injectors on your obd0 harness help!!!
how do you wire up obd1 injectors on your obd0 harness??? i have a 1990 crx si. i did the wiring but it still didn't work. the spark plug wires spark but ticks slowly. but isn't that enough to fire up some fuel??? i take out the spark plugs and there isn't any burn marks... i did take out the resistor box and splice it up together. but i didn't do that at first. how do you know if you fryed your injectors??
pretty much that is all u do
but if u didn't do this first probably u did
I got some obd1 injectors
whats the easyest way of wiring an obd2 ls in? How would you handle the obd2 pluging into the crx harnes. I know I could get a obd1 conversion for the ECU but what do you do about the engine? should i pull the pins on the d16 plug and use it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay_blu1983 »</TD></TR><TR><TD CLASS="quote">whats the easyest way of wiring an obd2 ls in? How would you handle the obd2 pluging into the crx harnes. I know I could get a obd1 conversion for the ECU but what do you do about the engine? should i pull the pins on the d16 plug and use it?</TD></TR></TABLE>
you have to make your own thread for a question...
But to answer you...You use the original car harness..If you want to use a jumper harness for obd0-obd1 thats plug and play....
use the search button..It helps everyone alot
e jay one
Sep 10, 2005 09:15 AM
nikitad
Jun 27, 2004 11:26 AM
