What clutch do I need?
Old Mar 28, 2002 | 05:10 PM
VTECVillain's Avatar
Default What clutch do I need?
I'm putting a 96 LS motor into my friend's 91 CRX and we're using a 92 LS cable tranny. Which year clutch does he need - one for a 96 or one for a 92? Will the 96 flywheel work or does he need one from a 92?
Old Mar 28, 2002 | 05:17 PM
B20zvtecek's Avatar
Default Re: What clutch do I need? (VTECVillain)
from what i heard u buy a cable clutch for the tranny Not exaclty sure though
Old Mar 28, 2002 | 05:57 PM
shairacer's Avatar
he will need 92+ integra clutch
Old Mar 28, 2002 | 06:19 PM
Default Re: What clutch do I need? (shairacer)
What about the flywheel? Will the 96 flywheel work with the 92 pressure plate and clutch disk?
Old Mar 28, 2002 | 06:38 PM
chhuong's Avatar
yep all b series flywheels are interchangeable, but the clutches are different you can only swap big splines/shaft with big splines/shaft, and small with small. The small ones are 90-91 tegs, first gen b16a, and maybe the 88-91 prelude not sure though, and the big splines are the 92+ b series. HTH
Old May 21, 2003 | 10:28 PM
baruba's Avatar
I just wanted to verify that all bseries flywheels are interchangable. So i could use say a '99 typeR flywheel in my LS cable tranny?
Old May 31, 2003 | 09:19 PM
EP Death's Avatar
Does any one know which clutch kit to use for the S1 tranny? I have a clutch kit for a 90-91 Teg, non-vtec and IT DOES NOT FIT. Sorry but I'm really pissed seeing how thi car ismy daily driver and it is on Jack stands. Please help me, what clutch kit do I need?
Old May 31, 2003 | 09:50 PM
Rywire's Avatar
Default Re: (EP Death)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EP Death &raquo;</TD></TR><TR><TD CLASS="quote">Does any one know which clutch kit to use for the S1 tranny? I have a clutch kit for a 90-91 Teg, non-vtec and IT DOES NOT FIT. Sorry but I'm really pissed seeing how thi car ismy daily driver and it is on Jack stands. Please help me, what clutch kit do I need?</TD></TR></TABLE>
Is it a jdm s1 tranny? Cause I have a jdm J1 (same as s1) and a 90-91 teg clutch worked perfect. What dosent fit, disk or pressure plate? It should be the disk that dosent fit if anything. Try a 92-93 disk I guess. Ryan
Old May 31, 2003 | 10:01 PM
incubus's Avatar
Default Re: (droppedcrxsi)
I have a JDM S1/J1 and I have a 90-91 teg clutch on mine.
I thought the 92+ clutches had too large of an input shaft to use on the 91 and lower? or something like that.
verify that your tranny is in fact a 90-91 S1. the tranny will have a silver sticker that begins with S1 and ity will have an ink stamp that says J1 nearby.
anyone else ran into this problem?
Old Jun 1, 2003 | 06:53 AM
Ruby Civic's Avatar
Default Re: (incubus)
crucial to check the spline size which you can check with those dick tools
i had ys1 tranny with big splines so of course got the small spline clutch disc and had to figure it out the hard way since it seemed like my plastice centering tool (dick) DID fit but the tranny did NOT
DA is best
Transmission & Drivetrain
Dec 30, 2010 11:10 AM
bOOsTiNSoHcVtEc
Apr 23, 2003 10:27 PM
Black R
Apr 1, 2003 10:39 AM
DOHCarp
Mar 14, 2003 09:04 AM
VTECVillain
Apr 4, 2002 07:21 AM
