Car won't start.... H22A4 into EJ8
Hey guys...
I have an H22A4 in a EJ8 (97 EX Coupe) and it won't start. Car cranks but does not start. I checked to see if the fuel pump is getting power, and it is not. Main relay is not making any noise. Could it still be bad? Where is the main relay in an EJ8....?
I also tried to see if I had a thermostat ground coming from my thermostat to a ground on the car. I did not. I added a 10 ga wire from the thermostat housing to the screw the battery ground connects to on the fender. Nothing.
Car just cranks and cranks, but makes no ticking noise, and I can't hear the fuel pump. I put in a Walbro 190 as well, brand new, hoping maybe that would solve the problem (before I tested to see if the pump got power).
So... main relay not clicking, thermostat housing grounded, and fuel pump fuse is good.
Any suggestions?
Thanks guys...
Any suggestions?
Thanks guys...
Relay is by the glove box. It's been a while since I looked at it but it is either next to the glove box or a little bit farther down on that side. There should be a seperate plug coming from the relay, make sure its plugged in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixgundone »</TD></TR><TR><TD CLASS="quote">Relay is by the glove box. It's been a while since I looked at it but it is either next to the glove box or a little bit farther down on that side. There should be a seperate plug coming from the relay, make sure its plugged in.</TD></TR></TABLE>
Found it.. thanks! Everything is plugged in... any ideas?
theofficialrj
21
Apr 12, 2015 07:48 PM
bimmeracer
Nov 3, 2008 08:46 PM
beak
Feb 25, 2006 05:53 PM
