Code 61 Exhaust problem... Advice?
My engine check light came on yesterday and the code was 61 for Primary heated Oxygen Circuit slow response. I was wondering if anyone else had experiance with this part malfunctioning and if anyone knew whether it is best to just replace the part or could there be a wiring or other problem.
Thank you
ps. I am assuming I can drive with the problem without causing further damage
Thank you
I got the same code. Got a new o2 sensor end it went away. I went to http://www.sparkplugs.com and got a denso sensor.
thank you
and am i looking at the right part?
http://www.sparkplugs.com/more...=1825
Modified by m.c. at 11:50 AM 2/24/2006
deftones0817
30
Sep 2, 2006 05:21 PM
