header on 96 dx problem!!!
ok so i got a header that only has 1 o2 sensor and my stock 1 has 2 im running check engine light and car idles like **** can i get another connecter and splice into the wires on the 1 and just plug it in or what should i do?
no he does not have one coming out of the cat if youre thinking of the cat underneath the car because only the ex/si have a seperate cat underneath the car. what you have to do is use your header and also buy a cat from a ex/si and run the o2 sensor back under the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-SI »</TD></TR><TR><TD CLASS="quote">no he does not have one coming out of the cat if youre thinking of the cat underneath the car because only the ex/si have a seperate cat underneath the car. what you have to do is use your header and also buy a cat from a ex/si and run the o2 sensor back under the car</TD></TR></TABLE>
yes i'm well aware of this seeing as i just put a header on my dx. its just sounded to me he was confused where the sensors should go
hatch96
Oct 12, 2003 05:37 PM
