have problem with idle reving
Old Feb 23, 2006 | 04:27 PM
sexdrg9's Avatar
Default have problem with idle reving
Have a 95 JDM spec prelude motor in a Del Sol and the motor started reving when at idle. Does anyone have a way to fix it. Driving me up the wall.
Old Feb 23, 2006 | 06:00 PM
hondaprelude93p13h22a's Avatar
Default Re: have problem with idle reving (sexdrg9)
Get a vacuum diagram from the library or something and rehose your vacuum sytem, or just try to find a leak on or around the intake manifold, if there is cap it off. Sometimes it could be a TPS (throttle position sensor).
Old Feb 25, 2006 | 08:38 AM
sexdrg9's Avatar
Default Re: have problem with idle reving (hondaprelude93p13h22a)
problem solved it was in the IAC, had to clean out coolant passage.
jakl
Apr 17, 2011 12:19 PM
PROJECT 91
Sep 25, 2009 11:18 AM
frathouse87
Sep 13, 2007 08:04 AM
rice a roni
12
May 24, 2005 12:31 PM
nevin
Dec 12, 2004 11:52 AM
